Old 08-17-2012, 10:45 PM   #1
tfbeitz's Avatar
1979 31' Excella 500
1973 25' Tradewind
Cinnaminson , New Jersey
Pressure Relief Valve ??
I am having problems with understanding the Pressure relief valve.
The PO capped one side.
Does the top of the valve blow?
With the water regulator being set at 45# and the pressure relief valve at 60#, I would think that there are other connections that would blow before the 60# relief valve.
Thanks in advance
Tom Beitz
6760 PA Unit
TAC NJ-5
Riverton, NJ
tfbeitz is offline   Reply With Quote
Old 08-18-2012, 03:03 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That valve has probably been capped because it failed, and started leaking.
There is a second failurepoint at the top of the valve as well. Ours failed there this Spring.
Old 08-18-2012, 04:10 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Your Airstream has an interesting collection of plumbing - all the major food groups appear to be covered.
My Overlander's original OPR valve did not leak UNTIL I tested its cracking pressure during the refurb. After that, it was replaced because it wanted to dribble.
I have noticed the new valve dribbles whenever the water heater is running. I do not consider that a problem because a tube connected to the device directs the water to the ground.
Tom
