Old 03-02-2008, 11:10 AM   #1
1974 29' Ambassador
Niskayuna , New York
Send a message via Yahoo to CBsquidSS
Pressure relief valve
I have a '74 Ambassador which just started draining water when connected to city water. The pressure relief valve is apparently sending some of the water out the drain. Is there an adjustment procedure for this? thanks, Jay
CBsquidSS is offline   Reply With Quote
Old 03-02-2008, 11:44 AM   #2
Jay.
No adjustments can be made.
The fix is replacement.
We have them.
Old 03-02-2008, 02:11 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Jay,
I agree that no adjustments can be made. Your pressure relief valve is probably designed to crack at 60 psi. The ones at most home improvement stores are usually rated for 90 psi.
Tom
Old 03-02-2008, 05:33 PM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Do you use an inline regulator? If not, you may want to try one before your swap it out....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-03-2008, 02:43 PM   #5
1974 29' Ambassador
Actually, after some studying of the situation, it only appears to be coming from the relief drain (I think). I checked out inside and the regulator is leaking just a bit, and the water is running down the outside of the drain tube, after saturating the floor under my twin bed. Looks like I will be replacing the regulator (and relief for s&g's)
What a relief to recover after Aluminitis ! qqq Our Community 16 03-19-2008 02:06 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Do I need this "second" relief valve? Fyrzowt Water Heaters, Filters & Pumps 20 11-22-2006 11:31 AM
Just a bit of relief to tweek your Airstream minds.... GT1963 Off Topic Forum 18 11-23-2004 11:19 PM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
