Old 01-04-2010, 11:17 AM   #15
Originally Posted by lebolewis View Post
Still searching locally for a replacement for my failed cold water pressure release valve. I understand that the original valve was designed to release at 60psi. I have found two possibilities.....one a valve that is fixed to release at 50psi......and another that is adjustable to release at 50psi or 75psi and in 25psi increments up to 150psi.
Does anyone know what the main adjustable cold water regulator in an Airstreams is factory set to?
Thanks, Bill
Airstream has the water pressure "regulator" set at 50 psi.
DO NOT use a pop off valve that's 50psi. If you do, it will continuously leak.
That's why Airstream's pop off valve is set to 60 psi.
If you cannot find the correct valve, Airstream has them available thru dealers.
Water heater pressure relief valve woliners Water Heaters, Filters & Pumps 6 07-10-2008 07:12 AM
pressure relief valve twiggy137 Plumbing - Systems & Fixtures 10 05-13-2008 08:20 AM
Pressure relief valve CBsquidSS Fresh Water Systems 4 03-03-2008 02:43 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
