Old 04-13-2010, 10:22 AM   #1
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Pressure Regulator Replacement - HELP!
My water pressure regulator is bad. It's a Watts no. 23, model A - Z1, set at 45 lbs. It's located in a very small space in the streetside rear corner of the trailer and I would like very much to get a "direct" replacement that has the same distance between the input and output ports. Re-plumbing to fit a different dimension will be very difficult because of very limited space and copper pipes. I've thought about just adding a regulator external to the trailer in the fresh water hose but would like to have a replacement if possible.
Anybody done this or have info on where I can get a direct replacement regulator? Bill
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 04-13-2010, 10:42 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Contact Watts directly at Watts Regulator Company - Plumbing, Heating and Water Quality Products Manufacturer They will have any info you need.
2004 Excursion 4x4
What is this thing off of the pressure regulator? uniquemicro Fresh Water Systems 14 04-15-2010 01:26 PM
pressure regulator question Woody.303 Fresh Water Systems 8 10-05-2008 08:17 PM
Water pressure regulator IndyAnne Fresh Water Systems 14 04-15-2008 12:26 PM
Pressure Regulator Cracker Fresh Water Systems 1 08-07-2004 12:05 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
