Old 10-02-2008, 08:10 PM   #1
Cincinnati , Ohio
pressure regulator question
Hello,
I'm new to this Airstream thing, so please forgive my ignorance.
I just bought this Airstream, and replaced a bunch of the old leaky copper. Now, when I turn the water on at the hydrant, I have a steady stream coming from the pressure regulator overflow.
Can I fix the pressure regulator? Or, do I need to replace it?
Woody
Woody.303 is offline   Reply With Quote
Old 10-02-2008, 08:30 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Woody!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by Woody.303 View Post
Hello,
Woody
Technically, the regulators used in the 1960s and 1970s are supposed to be rebuildable; but my local plumbing distributors have all indicated that the parts package is a special order that could take several weeks.
My solution (the regulator failed in my '78 Minuet recently) is to buy a new regulator to replace the non-working original. Once the water system is again functional, I'll take the regulator to one of my local plumbing supplies and have a rebuild kit ordered (I will keep the rebuilt original as a backup).
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 10-03-2008, 07:12 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You could also cut that sucker out and use a pressure regulator that screws in between you city water hose and city water intake fitting. They cost $10 - $15.
Old 10-03-2008, 09:33 AM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
Reulator
Woody
We do have the replacement valve from Airstream.
Click here for the link
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 10-03-2008, 10:15 AM   #5
Hello,
Woody
We have that part, too.
Old 10-03-2008, 10:22 AM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Last year I got an adjustable regulator with a gauge that I attach to the water supply faucet. It not only protects your unit, it also protects your hose, and you can adjust the pressure down to just what you need.
Old 10-03-2008, 05:05 PM   #7
rogerdodger's Avatar
Fresno/Clovis , California
Adjustable water pressure regulator
Hi Jim Foster. Where did you get it??
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 10-04-2008, 05:57 AM   #8
Dan@LED4RV's Avatar
Regulator
Here is one like Jim is talking about. It is not adjustable, but preset to 10 PSI lower than any RV standard. It also works for air. In other words, if the air compresser you use to blow the water out of your water lines is set to PLUS 90 PSI, it will keep the pressure low enough to keep from causing damage.
Here is a link.
Dan
Dan Brown
Denton NC
Old 10-05-2008, 08:17 PM   #9
Cincinnati , Ohio
Thanks to all for the replies.
What is the max pressure allowed in these Airstreams?
Woody
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Water pressure regulator IndyAnne Fresh Water Systems 14 04-15-2008 12:26 PM
location of pressure regulator jasper2222 Fresh Water Systems 3 11-25-2007 07:50 PM
Pressure Regulator Cracker Fresh Water Systems 1 08-07-2004 12:05 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
