Old 07-16-2004, 07:45 PM   #1
Cracker's Avatar
Pittsfield , Maine
Pressure Regulator
I just spent the better part of the afternoon replacing my pressure regulator at the water inlet. We have had very low pressure from the curbside hookup and I was sure that the culprit was the regulator. We had been using the on-board pump to boost the pressure - simultaneously drawing from the tank. Once the job was completed I began to examine the suspect regulator and found that the intake screen was jammed with trash - obviously the cause of the low pressure! I'm reporting this, with egg on my face, in the hopes of saving someone else the pita of changing the regulator - and the $39.50 cost of a new one.
Cracker
Cracker is offline   Reply With Quote
Old 08-07-2004, 12:05 AM   #2
delquattro's Avatar
Thumbs up Thank you for your post!
My wife and I just picked up our first Airstream and the pressure isn't what it should be. No leaks anywhere. In fact, I turned off the city water, left the hose connected and hours later went to disconnect at the trailer and it had held pressure. When a faucet is initially turned on the pressure is great, but quickly bleeds down to a trickle. I think you may have pointed me in the right direction. Thanks.
delquattro is offline   Reply With Quote
Rego LP Regulator? TomW LP Gas, Piping, Tanks & Regulators 9 01-30-2008 08:58 AM
too much pressure? Chas Water Heaters, Filters & Pumps 23 04-28-2004 09:31 AM
Fix or replace LPG regulator? Roundhead LP Gas, Piping, Tanks & Regulators 26 03-27-2004 03:28 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
