Old 06-30-2009, 12:59 PM   #1
1978 31' Sovereign
Mukwonago , Wisconsin
Potable water tank nasty
Hello I an a classic car guy who is intending to restore a 1978 Airstream International. The tank has black slime in in from lack of use and I can not find a drain for it. Is there an easy way to clean or remove it. It is just inside the driver side wheelwell. This unit has a center bath. Thanks!!!!
jeepguy is offline   Reply With Quote
Old 06-30-2009, 02:12 PM   #2
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Have never seen one without a drain on the fresh water tank somewhere. There are recognized ways to sanitize such a tank - search on the Forums for "sanitize" and you will find them. They involve adding ordinary household bleach to the partially-filled tank, then filling it all the way with fresh water, running this solution out of all taps, shower head, etc. for a bit using the coach's pump, then letting it sit for a pre-determined amount of time, then draining (you can always use the water pump to pump out the tank) and refilling. Most do this every year and sometimes more often.
Good luck - and welcome to the Forums.
AirsDream is offline   Reply With Quote
Old 07-01-2009, 08:41 AM   #3
1978 31' Sovereign
Tank sanitization
Thanks. I suppose the oxidizing action of the bleach will dissolve the slime???? I was hoping to flush it somehow... I will go drain hunting. Thanks again Jeepguy
Old 07-01-2009, 10:10 AM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
It may be a good Idea to tow the trailer around while it is half full with the bleach solution. That way the sloshing of the water should help dislodge the ectoplasm that is inside your tank.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-01-2009, 11:51 AM   #5
2008 16' Safari
Destrehan , Louisiana
There is a drain for it. Look under the floor near the galley. You'll find a water pump there. Follow the lines back to the tank inlet. The drain is there. You can't see it from under the trailer.
dlb435 is offline   Reply With Quote
Old 07-21-2009, 09:57 AM   #6
1978 31' Sovereign
Thanks to all. Drain is actually a plug directly below fill inlet behind an access cover that has the winter drain down tube passing through it. I was looking for a valve assembly of some type. Got it now... Thanks!!!
Potable water tank drain annie oakley Waste Systems, Tanks & Totes 1 05-26-2009 04:17 PM
City Water Connection to Potable Tank? Motoman Fresh Water Systems 2 12-19-2006 06:22 AM
Potable water balrgn All Argosy Trailers 4 03-11-2005 11:07 AM
Potable Water Tank Lee Pace Fresh Water Systems 4 09-01-2004 07:44 PM
69 Overlander Potable tank Lee Pace Dehumidifiers & Ozone Generators 8 11-24-2003 08:21 PM
