Old 07-16-2009, 11:06 AM   #1
1991 25' Excella
1987 29' Sovereign
Pace , Florida
Potable Water Tank Leak
My wife and I own a 1991 25 foot Excella Classic. Recently while hooked up to city water, we noticed water dripping from the inspection plates in the belly pan directly beneath the potable water tank. Anyone got any ideas on what is going on?
Danny Lombardozzi
Silverado 2500HD/1991 25" Excella Classic
dlombardozzi is offline   Reply With Quote
Old 07-16-2009, 01:17 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I just had the same thing happen on my '86 Sovereign. It was the plug on the bottom of the potable water tank. There are some threads on this problem (I'm not sure how to put a link here). The hardest thing for me was to remove the cover for access. The plug has a hex type hole in it. A 1/2" bolt head fits right in the hole so you can turn the plug out. Put two nuts locked on each other so you can turn the bolt. Turn out the plug gently. Clean it up & put either teflon tape or plumber's putty on it (I used the putty). It should be fine for another 20 years or so. Some people replaced their plugs, but mine was in good shape. Make sure yours hasn't shrunk before you put it back in. I put my cover back on with rivets because the screws were really hard to get out.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Potable water tank nasty jeepguy Fresh Water Systems 5 07-21-2009 09:57 AM
Potable water tank- How many gallons? Zstream Fresh Water Systems 0 07-02-2009 05:40 AM
Potable water tank drain annie oakley Waste Systems, Tanks & Totes 1 05-26-2009 04:17 PM
City Water Connection to Potable Tank? Motoman Fresh Water Systems 2 12-19-2006 06:22 AM
Potable Water Tank Lee Pace Fresh Water Systems 4 09-01-2004 07:44 PM
