05-07-2008, 01:29 AM
#21
2002 25' Safari
Dewey
Originally Posted by DEITZ645
The piping in my '06 is PEX and I love it. The piping in the '87 is a grey plastic. I don't think it is PEX or PVC. Does anybody out there know what they used in the '80's era trailers?
Could it be Polybutylene?
Richard
05-07-2008, 04:54 AM
#22
2006 30' Classic S/O
Mohrsville
, Pennsylvania
That's The Stuff
Ricahrd,
Thanks, Polybutylene is definitelt what I have in the '87. One more mystery solved .
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
05-27-2008, 09:06 AM
#23
1967 20' Globetrotter
Sauquoit
, New York
Thanks all for all your info. We located a hairline crack in our main line.
Material to be used ...thanks to you...will help. Thanks again, Aria
05-27-2008, 09:48 AM
#24
1998 31' Excella 1000
South Berwick
, Maine
Isn't there a class action law suit filed for any polybutylene installations?
WBCCI 24291
New England Unit
Metropolitan NY Unit
05-27-2008, 02:21 PM
#25
2011 34' Classic
Westchester Cty.NY
, / Miami FL
Ricky
05-27-2008, 05:17 PM
#26
Ottawa
, ON
Originally Posted by bobfowler
I'm jumping in here kinda late, but...
I soldered up two copper manifolds with 1/4 turn ball valves for hot and cold water (located under the bathroom sink). All lines from the manifolds to the fixtures are braided stainless steel supply lines from Lowes. I de-winterized and used the trailer in mid-April - plenty of pressure with either the on-board pump or city water. If those puppies burst, I've got a MUCH bigger problem...
Pardon my ignorance, but what does the manifold do?
05-27-2008, 06:55 PM
#27
1972 25' Tradewind
North Vancouver
, British Columbia
Quick answer:
Plumbing Manifolds
North Vancouver, BC
05-27-2008, 08:52 PM
#28
Ottawa
, ON
Originally Posted by cameront120
Thanks, Cameron. Wow, how cool! It's like Central Command for water supply (hot & cold) to all fixtures.
So is the point as it concerns TTs to centralize all the shutoffs for seasonal shutdowns and emergency use?
Looks like a very organized way to go.
I would imagine that PEX is cheaper and safer to install since it doesn't require a torch. How do the materials costs compare to copper?
05-28-2008, 08:12 AM
#29
1972 25' Tradewind
North Vancouver
, British Columbia
Centralization of valves is the very reason a manifold is so nice. Especially for a trailer where you can locate it in a location with easy access and then run individual cold and/or hot lines to the point of use. Material cost for Pex and fittings is more than that of copper, but the savings are in the labor. Also, no soldering and less chance of split pipes if they aren't thoroughly drained in winter.
North Vancouver, BC
05-28-2008, 12:33 PM
#30
Ottawa
, ON
Thanks.
01-21-2010, 10:00 AM
#31
1984 29' Sovereign
Savannah
, Missouri
Originally Posted by Fyrzowt
That's because you haven't had your pipes freeze yet. In that case, the PEX is better.
I like this idea too. I would suggest a drain down through the floor and belly pan so it would allow the water to exit the coach with no further damage. It (the leak) would still be quite noticable IMO.
Dave
You are so correct~!
I once had a 64 GT, that a PO forgot to winterize, and he let the copper pipes freezes over that winter.(Afterwards, I am guessing, he never had any further problems..lol) Plastic? Gawd, I could not agree more. As much as I love vintage Airstreams, the use of plastic makes my blood boil~! I am, like everyone else, finding new breakage from the aging of same, which resulted from brittle plastics.
The latest on my 84 unit is the city water overflow or drain control knob. Wouldn't you know it? It's plastic~! Do you know how hard this is going to be to replace?? What were they thinking of at Airstream??
It is no wonder why we love Airstream..lol
WBCCI 5292 AIR 807
NEU #64
New England Unit
01-26-2010, 04:20 PM
#32
1965 28' Ambassador
Irving
Originally Posted by fotochop
- very informative thread...glad my unit has already been replumbed with PEX and sea tech fittings...I wish so much of it didn't live behind the vacu-formed plastic bath, but I guess that's why they sell 1/8" rivets by the gross and harbor freight makes a 30 dollar air pop riveter ;-)
I noticed that Harbor Freight riveter is now $39.Have you used one?
01-26-2010, 04:24 PM
#33
1965 28' Ambassador
Irving
The the new pex fitting tool looks really easy.A video on the new Flairit Pro pex is on iplumb.tv
#34
1967 22' Safari
1960 Caravel
Edmonds
I have one it works OK. It beats the heck out of putting in a bazillion rivets by hand.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
01-26-2010, 04:34 PM
#35
1965 28' Ambassador
Irving
Lee , do you use a water manifold?
01-26-2010, 05:09 PM
#36
1967 22' Safari
1960 Caravel
Edmonds
No, It didn't cross my mind when I redid the plumbing. I mimicked the stock setup.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
03-02-2010, 11:55 PM
#37
1970 31' Sovereign
danville
I know this is my first post in a almost old thread, but as a plumber by trade I would personally never use pex. The reason it has taken so long to be passed in all of the state plumbing codes is it has been found to be carcinogenic. And up until now most states have been against it, but the pex company put enough money in enough pockets to get it passed to the plumbing code. I know most do not use their rv as their main source of drinking water. I am just saying its anothing thing to think about.
Stick to copper and common sense, the laiter is worth a heck of a lot more.
03-03-2010, 08:08 AM
#38
1967 22' Safari
1960 Caravel
Edmonds
Welcome to the forums
Hi gmwelder86, Can you post some information on this? I did a quick web search and did see anything to back this up. http://www.documents.dgs.ca.gov/bsc/...2010.16.08.pdf and http://www.documents.dgs.ca.gov/bsc/...%20Terrace.pdf.
I like copper, but PEX has made plumbing for the DIY types a lot more simple.
I'm not saying it isn't true... I just couldn't find any info.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
03-03-2010, 10:30 PM
#39
1965 28' Ambassador
Irving
When I got my AS the plumbing had been redone,but not hooked up.Probably due to the 8in. crack in the fresh water tank up front.I want to redo with PEX.The lines ran in plastic down the CS to rear across back and back up the SS to the sink.Is this the regular routing?
03-04-2010, 04:49 AM
#40
I know this is my first post in a almost old thread, but as a plumber by trade I would personally never use pex. .
I found lots of info on PEX and Prop65 in California.
One of the opinions is that plumbers in California are against PEX because it takes work away from plumbers and gives it to the DIY homeowner. And that it's the Plumbers Union putting money in the Legislatures pocket to hold it back.
