Old 06-15-2009, 02:50 PM   #1
1986 34.5' Airstream 345
Tyler , Texas
poor pressure
Hi! I seem to have a water pressure problem on both the water pump and on the city water supply. Both have great pressure when first turning on the faucet but quickly go to a drip only mode. I have cleaned all of the screens and cannot understand the low pressure since the regulator is for street water only and not the battery operated pump. Thanks'jPete
pjude is offline   Reply With Quote
Old 06-15-2009, 04:24 PM   #2
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
This may sound stupid as you checked the screens but we had a very similar problem. I unscrewed the aerators on the nozzles of both faucets and found small white pieces of sediment. I just tapped them out, rinsed the screens and all was well.
2007 Safari FB SE LS
2008 F-250 Lariat Power Stroke Diesel Crew Cab
WBCCI 1538
To err is human. To arrrrrrr is pirate.
altamont is offline   Reply With Quote
Old 06-15-2009, 04:25 PM   #3
altamont's Avatar
Tracy , California
As another thought. Unscrew the ends of the faucets and then run the water. If the pressure seems OK, then it would be the aerators or screens causing the problem.
WBCCI 1538
Old 06-15-2009, 04:33 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
The only thing I can think of would be a valve that is just almost shut off,allowing water to seep thru and then build up pressure.But I know of no valve that would control street and pump water.Dave
easyride is offline   Reply With Quote
Old 07-28-2010, 01:15 PM   #5
1973 29' Ambassador
El Paso , Texas
Did you ever get this figured out? I am having the same exact problem.
bdavolley is offline   Reply With Quote
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Our Poor '79 Tradewind Coloradobus General Repair Forum 9 04-13-2008 06:49 AM
HELP - Poor Pedal Pressure swebster Mechanics Corner - Engines, Transmission & More... 10 10-28-2003 06:13 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
