Old 10-05-2012, 08:19 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Poly fresh water tank repair-solder iron
Anyone have success with poly tank repair with poly pieces and solder iron?
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 10-05-2012, 10:50 PM   #2
1977 Argosy 24
Milltown , Wisconsin
I did with my 77 Argosy tank, and so did a friend of mine with a 75 Argosy tank. Just melt scrap pieces into the crack as you melt the crack together with the tip of the iron. If it still leaks do it again and fix it.
ventport is offline   Reply With Quote
Old 10-06-2012, 04:56 AM   #3
Ventport, thanks for the reply. I did the repair, but still have a pinhole leak. Will do it again, I have lots of scrap, I cut a 5" hole for an inspection/cleanout port.
Roger
Air# 29488
Old 10-06-2012, 07:01 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Harbor Freight has a hot air plastic welder for cheap. It might make the job easier. I have used it to repair some door panel cracks on a old car with success.
Good Luck,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-06-2012, 07:36 AM   #5
Thanks JD, I'll check it out! I need a reason to visit Harbor Freight Tools.
Roger
Air# 29488
Old 10-06-2012, 06:31 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have used a small gas torch (gotta be extra careful), we also have hot air welding guns at work that I have snagged before. The ones we have are the Leister brand. I use a very small tip and plenty of fill material. I have repaired a couple of different types of tanks with success.
Aaron
WBCCI #XXXX AIR #2495
Old 10-07-2012, 01:46 PM   #7
I went back over the pinhole leak again, added more plastic. It is holding now with 1/2 tank. The leak is at the bottom at the hump to stop water movement. Will fill to the top, give it 24 hours. If still holding, back in the trailer it goes. Thanks all for the responses.
Roger
Air# 29488
Old 10-07-2012, 03:49 PM   #8
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
There's a number of that might help...
