Old 04-02-2004, 04:04 PM   #1
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Question Plumbing/water filler
I hooked up the water to my Caravel for the first time yesterday. After several trips to the hardware, all water lines are intact and not leaking.
BUT when I leave the garden hose on, the tank overfills, pops open the water filler on the streetside and overflows. No shut-off valve to that line is visible.
Does anyone know what I'm missing?
Rog
Name:	water filler.jpg
Rog0525 is offline   Reply With Quote
Old 04-02-2004, 04:09 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
There should be a check valve in the water pump to prevent this from happening. The outlet of the pump is "Teed" into the same line that the city water connects to. This is the only way I know of for water to fill into the tank unless the PO added some sort of valve to bypass the pump check valve. I would start with the pump.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-03-2004, 08:01 AM   #3
Rog0525's Avatar
Images: 11
Thanks Brett. The original valve is either shot or was removed by PO. That water line is a combination ov pvc pipe and rubber hose. Looks like the easiest remedy will be to cut the hose and add an in-line check valve.
Rog
Old 07-19-2004, 06:39 AM   #4
Rog0525's Avatar
Images: 11
I installed a check valve in the 1" line but the water fill still overflows. I discovered that there is a second hose, maybe 3/8" leading to the water fill which is leaking at the bottom, near the top of the fresh water tank. I'll have to remove the furnace ductwork to get to it.
Why 2 lines to the water fill? What to do?
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Old 07-19-2004, 06:53 AM   #5
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
That second smaller line from the top of the tank to the water fill is a vent line. When you are running a hose into the tank full on the vent stops you from getting all wet
Did the check valve stop the auto fill you were experiencing?
Brett G
Old 07-19-2004, 07:01 AM   #6
Rog0525's Avatar
Images: 11
Thanks for the reply Brett. The check valve did not stop the overflow. I am filling with a garden hose to the rear water connector.
Rog
Old 07-19-2004, 07:32 AM   #7
Rog0525's Avatar
Images: 11
From what I can see, it's kinda like this:
Rog
Old 07-19-2004, 07:46 AM   #8
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Rog,
The drawing you posted shows a check valve on the inlet from the exterior fill?
The check valve should be on the outlet line from the tank, the one that feeds the pump. This should be a 1/2 to 3/4 line. I am still betting on the pressure feed thru the pump to the tank theory.
Brett G
Old 07-19-2004, 07:59 AM   #9
Rog0525's Avatar
Images: 11
What a mess! I really won't know more until I remove the furnace duct to get a good view. I can see that the bottom of the small rubber hose is split and that is why it is leaking. What I cannot see is where the check valve should be. Looks like dummy me put the check valve on the wrong line.
Rog
Old 08-01-2004, 07:25 PM   #10
Rog0525's Avatar
Images: 11
Thumbs up Fixed......knock on wood
Removed the ductwork today and got a much clearer view of the plumbing. 2 manual shut off valves were hidden by the duct. I replaced 2 hoses which had split ends and one that was nearly cracked. Fiddled with the valves to find the right combination.
Very tight quarters to work in but glad I was able to fix the leaks before any permanent damage.
These old coaches are a constant source of mechanical education. Learned a plumbing lesson but am far from being a skilled plumber. What is the correct amount of butt cleavage to display?
Rog
Old 08-01-2004, 09:00 PM   #11
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Originally Posted by Rog0525
.....Learned a plumbing lesson but am far from being a skilled plumber. What is the correct amount of butt cleavage to display?
Only enough to make the children giggle but not point and laugh.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Hardwood Concern J&C Floor Finishes 24 04-03-2004 02:54 PM
Help - I'm Confused timcumming Clearcoat, Exterior Paint & Trim 16 02-26-2003 01:23 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
Retrofitting Old Propane Tanks (non-opd) leslie LP Gas, Piping, Tanks & Regulators 18 09-20-2002 10:24 AM
