Old 03-14-2013, 06:09 AM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Question Plumbing Size?
Hi,
Getting ready to pull out the old leaky/patched copper plumbing in our '59 Tradewind. I plan on installing PEX.
Any tips on what size to use? Should use 1/2" or 3/8" or a mixture of different sizes?
steveirving is offline   Reply With Quote
Old 03-14-2013, 06:29 AM   #2
1986 31' Sovereign
Miami , Florida
Granted, my trailer is newer than yours (86) but I can tell you that most of the main runs are 1/2". With the pressure regulator on mine set at 40psi, that gives me pretty good flow rates. The leads that branch off the main to the bathroom sink are 3/8" though.
I used PEX and Sharkbite fittings for the few repairs I've had to make and all has held up fine.
Mike
n2916s is online now   Reply With Quote
Old 03-14-2013, 06:30 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by steveirving View Post
Hi,
Simple answer, you want the nominal diameter of the PEX to be the same as the nominal diameter of the copper you're replacing. Inside diameters will be slightly different for the same nominal diameter, but that doesn't matter for this application.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-14-2013, 07:41 AM   #4
Central , Mississippi
1/2" PEX is widely available, 3/8 can be a bit more scarce - thus my choice to go with 1/2" all the way.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-14-2013, 07:43 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I used 1/2" throughout. That way all of the fittings are the same size. Also used the flexible braided stainless lines to connect to all fixtures, including the water heater. I posted some pics on my blog.
TG Twinkie is online now   Reply With Quote
Old 03-14-2013, 07:47 AM   #6
Yup, I used 1/2" throughout because it was the most common and available size.
Old 03-14-2013, 08:32 AM   #7
1966 20' Globetrotter
1985 25' Sovereign
johnsoncity , Tennessee
Most 1/2" Pex is 3/8 inside diameter. I would stay with 1/2" myself.
donh1 is offline   Reply With Quote
Old 03-14-2013, 01:17 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Like others have said 1/2", bigger is better.
The only place it is good to restrict water flow is at the point of use, such as where it comes out of the shower head, not where or before it goes into the shower head, that way you still have pressure.
Old 03-14-2013, 01:48 PM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
Hi,
3/8" is completely sufficient, in terms of flow rate, for any runs that serve a single fixture. Smaller pipe means less water wasted running the tap until the water gets hot or cold, as the case may be. And although there isn't much difference in the weight of the pipe, using 3/8" will reduce the weight of water and fittings by a couple of pounds.
Most people, including the mother ship, just use 1/2" because then you only need one crimp head and one size of fittings and pipe.
Old 03-14-2013, 01:55 PM   #10
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
...also, you can buy red for hot and blue for cold. I started using PEX about 7 years ago when I added plumbing in my house...used it throughout my pool house and for other projects. Sharkbites work....but I dropped the coin and bought a crimp tool (around $100)...it came with multiple heads so I can use it with all sizes of PEX. You can also find fittings that'll let you connect it to copper and even PB pipe. Once you use it you will never go back to anything else. GREAT for DIYers and most builders are now using it in new home construction. Side benefit: it has a bit of give if there's a freeze...unlike copper.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-18-2013, 04:33 PM   #11
1959 24' Tradewind
Quantico , Virginia
Images: 11
Any thoughts on crimps vs clamp pex?
Old 03-19-2013, 08:36 AM   #12
1985 25' Sovereign
Cannot tell you what to do, but will say i have replumbed three houses using the crimp method.HAVE HAD ZERO LEAKS, THIS HAS BEEN OVER A FIVE YEAR SPAN. I am not a trained plumber. I would spend the money to buy a good crimper tool. (I bought mine at Lowes big box store.
Old 03-19-2013, 08:45 AM   #13
Kevin245's Avatar
Ditto here. I will say that crimping requires some forethought as the tool size can limit access when working in tight spaces.
Kevin
Eleanor Roosevelt
