Old 03-24-2005, 04:03 PM   #1
plumbing questions
My new home has some plumbing problems. The copper lines are split in a couple places, and the fresh water tank is cracked (I am sure I'll find more wrong as I work my way back.) I ordered up some PEX tubing and the crimp tool, but I have some questions.
The copper pipe was running on top of the floor. I have some of the floor torn out in the front of the trailer to replace some rotten plywood, and it looks like it would be easy to run the PEX line under the floor, through the frame. How is it susposed to be? pipe above the floor, or below the floor?
Any ideas were I can get a new fresh water tank? It does not have to be airstream, as long as it fits.
Thanks in advance for the help!
Jon
hickam is offline   Reply With Quote
Old 03-24-2005, 04:43 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Welcome to the forum! If you ever need to get at it again, you may want to leave it run as it was or find a route that hides it.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-24-2005, 05:02 PM   #3
So originally, the plumbing did run on top of the floor in the front?
Old 03-24-2005, 05:14 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
The plumbing lines ran originally above the floor. In cold climates, it would keep the pipes from freezing if the interior was heated. Also makes it easier to repair, if needed. As for the tank, try all-rite.com. They have a huge selection of tanks and will put in the connnector holes to your specifications and placement requests. Best of luck.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 03-24-2005, 06:32 PM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Yes something like this.
Name:	Water lines.jpg
www.balrgn.com
Old 03-25-2005, 10:05 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
FF
any idea what they might get for a moderately sized tank? I got quoted over 400 bucks from a local outfit for a custom-made tank.. the pre-fab ones go for half that.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-25-2005, 11:31 AM   #7
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I went through a local RV shop and paid just over $200 for the tank. Don't think I paid for shipping, can't remember. I went to All-Rite's website and picked the largest size that would fit. When it arrived it was exactly the measurements as list on the website. Fit like a dream.
FF
Old 03-25-2005, 01:23 PM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
so, it sounds like you got a "pre-fab" one? they don't list anything on their website but "custom" tanks, now. if they still have pre-fabs, they either don't list that info on their website, or I can't find it.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 03-25-2005, 01:41 PM   #9
Images: 59
You can try this place. They ship. http://www.accutanks.com/ronco_water.htm
Old 03-25-2005, 01:48 PM   #10
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Back when I needed a tank in early '02, they had several pages of different size tanks. I ordered the 30W and they put the fitting holes in the size and location I requested. I don't know if it was from stock or they built it when I ordered it. They have changed their website and how they handle tanks since them. Probably tough to keep a number of ready to order tanks in stock.
I didn't see a price for one of these tanks. Have you inquired?
FF
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
