Old 05-09-2007, 10:49 PM   #1
AIRSTREAM RESTORATION
1966 17' Caravel
n hollywood , California
Plumbing Question...
I installed a new water pressure regulator, but I need to know the psi to set it at. Thanks!!!!
triplesixx is offline   Reply With Quote
Old 05-10-2007, 12:21 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
How do you know what its set to without a guage of some sort?
IIRC, most of these are set to 40lbs or so. I believe that is what the simple hose-end regulators are fixed at; all you "need" to set it to is something less than your pipes are rated for...or, 5 lbs less than that pop-off valve in the pic.
seriously, 40-50lbs is probably fine.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-10-2007, 03:18 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The 72 service manual we have says 32 to 38 pounds - set pressure with all valves closed (duh). We also use a hose end regulator that Chuck mentioned above - just for overkill - it's preset at 40.
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
General plumbing question eracism Fresh Water Systems 2 01-14-2003 06:41 AM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 09:00 AM
