Old 06-29-2006, 04:34 PM   #1
1966 22' Safari
Bedford , Virginia
plumbing question
We recently bought a '66 Safari and have a question about the pipes. Are ABS pipes that are used in mobile homes the same pipes that are used in campers? Thanks for any help.
wkendcamper is offline   Reply With Quote
Old 06-29-2006, 04:51 PM   #2
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Camper,
I'm not real sure how old ABS piping is.
I know it's been around for 30 years. Maybe longer.
However, You can hook together ANY kind of pipe if you use what is called a Mission Coupling. A mission coupling will allow you to connect abs to pvc to copper to steel to cast iron. It is a rubber coupling surrounded by a stainless steel band with 2 hose clamps to cinch it down. I use them all the time in my remodeling business where you need to move a sink or bath tub or the like.
Often I have to cut into the old cast iron or steel drains and when I do I just reconnect every thing with plastic (abs or pvc) and a couple of mission couplings. They are readily available at any of the big box stores such as bLowes or Home Despot.
HTH
Jerry
Ultradog is offline   Reply With Quote
Old 06-29-2006, 04:56 PM   #3
1966 22' Safari
Bedford , Virginia
Thanks for the info, Jerry.
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
General plumbing question eracism Fresh Water Systems 2 01-14-2003 06:41 AM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-29-2002 11:02 PM
