04-20-2014, 06:00 AM
2014 28' International
Frederick
, Maryland
Water shutoff valve - help needed
I just got a 2014 25FB Flying Cloud and am in the process of dewinterizing it. There is water flowing out of this tube and I would appreciate any help in locating the valve. I've located multiple valves, but not the one that controls this. I am assuming that it may be an overflow for the hot water heater since it is right below that area. I've attached a picture of both the tube and the hot water heater.
Thanks!
04-20-2014, 06:52 AM
1988 25' Excella
Trumbull
, Connecticut
Drain
Hello AirReg. I don't think the water heater has an overflow tube. Ar least mine doesn't. That tube is either the drain for the frig or the drain for the AC. Good luck
Happy camping nm1oqrz
Thanks!
Attachment 210065
Attachment 210066
04-20-2014, 06:57 AM
Frederick
, Maryland
One other note, when the city water is connected, water comes gushing out of this tube. No problems otherwise.
04-20-2014, 07:07 AM
Frederick
, Maryland
Plumbing Diagrams - 2014
I am trying to determine why water gushes out of a white tube under where the hot water heater is in my 2014 Flying Cloud 25FB. My manual has plenty of electrical diagrams, but no plumbing diagrams.
Does anyone know where I can get one?
04-20-2014, 07:14 AM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
I believe it's a low point water drain.
If I recall AS started putting a white panel next to the water heater side in the storage bin.
Older (prior to 2014) versions did not have the panel which hides the water heater, and your shut off valve is probably behind that panel.
04-20-2014, 07:48 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I find it hard to believe that with a 2014 Airstream you did not receive an owners manual. I would get one, regardless.
http://www.airstream.com/files/libra...1ff0dca86b.pdf
04-20-2014, 07:57 AM
Frederick
, Maryland
Fixed!
That worked! Thank you very much.
04-20-2014, 09:32 AM
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
Could that have been a drain that was left open from winterizing? Can you follow the tube to a shut off valve?
Judging a person does not define who they are, it defines who YOU are.
