Plumbing diagram for 76 tradewind rear bath
Hi there,
I've been searching this forum for a couple hours and figured I would start a thread since couldn't find anything. I have a 25' 76 tradewind that has not been used with plumbing for at least a decade. I moved it to an rv park and hooked up to the city water and there are some leaks. Some obvious, others not. There is water coming up from under the Lyno by the refrigerator. I'm thinking the fresh water tank is there and I remember the previous owner telling me that the freshwater holding tank is cracked. From reading here, I gather the check valve is broken and allowing city water to go into the tank. I have the original manual which as you all know is very secretive! Does anyone have a fresh water plumbing diagram for this model? I found a drainage system pdf for 27,29, & 31 full bath but I would also love one for my
model if it's different. Most important though, for now is the fresh water diagram.
Thanks in advance.
Jane
