Old 10-21-2003, 03:38 PM   #1
jack simons's Avatar
Plumbing
Help! I just bought a 1976 Argosy 26'. Trouble is, the previous owner didn't winterize the fresk water tank. The plumbing system froze and now the entire system is riddled with leaks. How about some imput on changing out the tubing so that I can get the water system up and running? Thanks. I was hoping to not pull the inside walls.
jack simons is offline   Reply With Quote
Old 10-21-2003, 03:50 PM   #2
1975 29' Ambassador
Reno , Nevada
replumb with pex. you can get color coded pipe at pexconnection.com or just use what Lowe's sells. You should be able to route it around and behind things without too much trouble. Connections are with Quest or Flair-it fittings or you can use a crimping tool. If you plan things a bit, you can make sure the pipe runs are easy to drain and all connections and fictures are fairly easy to get at. Use the 3/8 tubing that mates to standard half inch pipe fittings.
The quest or flair-it fittings will also work on copper tubing so you can mix new Pex with old copper if you want to without too much trouble.
Use flexible sink hookup line (I like Tru-Value Hardware's selection and type) for short runs (< 3 ft) and for the pump connections. They reduce vibration and are easy to disconnect to help in drainage.
But, if your tanks are leaking, replacing them can be a pain.
Toilet valves and complex one handle valves are most subject to freezing damage, too.
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
plumbing pics for '77 Sovereign? maznblu Plumbing - Systems & Fixtures 3 04-14-2004 07:27 PM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 12:56 PM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
