Old 11-05-2006, 04:55 PM   #1
2006 28' Classic
Lake Tomahawk , Wisconsin
Please! an honest answer?
Asked once before and didn't get an answer! Why did the Airstream engineers put the water fill on the curb side of the (2006 Classic). Why not by the city water side or direct from the city fill?
Would someone give me a logical answer!
Especially since I overflowed the tank and ended up with much water on floor and carpet inside.
William Ales is offline   Reply With Quote
Old 11-05-2006, 05:19 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
If I knew, I'd give an answer!
I can only guess that it may have to do with the location of the fresh water tank. Another thought - if you want to fill from your hose at home, many, if not most folks, will park in front of the house to fill. That puts the fill closest to the yard and the faucet.
Sorry, that's the best I can come up with right now, maybe someone else will chime in.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-05-2006, 05:20 PM   #3
2006 30' Classic
Farmington , New Mexico
Images: 14
Will ----The only reason I can think of is that it makes access to the filler hose easier . If you lift the floor of you closet you have access to the major plumbing components, pump ,filler hose connections, level sensor, etc. . If it were on the otherside they would have either the bath or the refridgerator to contend with. I fail to understand how over filling the fresh water tank would allow water to get on the carpet. It should just run out the filler or little vent at the neck. ---pieman
Mike Lewis is offline   Reply With Quote
Old 11-05-2006, 05:59 PM   #4
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
DUH, maybe it's so you won't fill up your fresh water tanks with the wash-off hose at the dump station, like the fellow I saw last summer at one of the Canadian Provincial Parks.
Your answer can probably be answered best by the same engineer who put the fresh water drain in a location that's practically impossible to access.
Hoenstly, I'd speculate that the real answer might have something to do with most economical location (as in "cheapest way").
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 11-05-2006, 06:52 PM   #5
2006 28' Classic
So far, what happens if the water fill is on the other side of the house!
Dumb engineers is the closest answer so far!!!
Motorhomes have the fill ability through the city water connection by a simple flow valve. And the reason I now find out was the fill pipe wasn't installed properly, most likely by the engineers son following his fathers genius.
Doesn't matter where all the plumbing "stuff" is located, still just a matter of a little pipe and a valve.
Someone has to know the engineer who did this!
Old 11-05-2006, 07:12 PM   #6
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
And why...
And why does the door on the 22' CCD swing open and block the view and operation of the window in the dinette,when it could easily swing in the other direction ?
ID:	28194 Click image for larger version
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
S C Streamer is offline   Reply With Quote
Old 11-05-2006, 07:19 PM   #7
1984 31' Excella
Norfolk , Virginia
Images: 11
I showed this thread to my beloved wife. Her remark was "a man had to design that like that, a woman wouldn't."
What can I say.
A Beginner, but not stupid.
Beginner is offline   Reply With Quote
Old 11-05-2006, 07:23 PM   #8
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
It's there because that's where the water tank is. If you're overflow is dumping onto the carpet, your overflow tube is disconnected either at the tank or at the fill connection. Overfilling the tank should only result in water spewing out the overflow tube, NOT dumping onto your floor and carpet.
Roger
Old 11-05-2006, 07:29 PM   #9
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Lets see, they had to put it somewhere ?
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-05-2006, 07:39 PM   #10
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Since I have never looked at one, and since you said it was wetting your floor/carpet, I sure hope you aren't mistaking the black tank washout for the potable water fill! If you are,that would explain the wet floor.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 11-05-2006, 08:15 PM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
Roger's response is the answer to the dousing of the inside of your trailer and it cannot be related to the roadside vs. curbside issue you raise.
My fresh water tank fill is roadside (locked under a small access door) -- this is right next to the city water hose attach point; the latter is immediately below the black tank flush. The city water and black tank flush both take the male end of a garden type RV hose. In Airstream's shoes I would probably decide this was a formula for problems. Instructions are to avoid using a potable water hose for the black tank flush -- and yes, I do carry an old hose in my rear bumper for the latter. I can't be sure that's the answer but if I'm close at all we should really be asking, "Will the Bambi & Safari lines get this same change?"
5 meter Langford Nahanni
Old 11-06-2006, 08:01 PM   #12
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I vote for Roger's responce.There are many days that I wonder why I bought a 71. Then I see a post about a 2006 that runs water out onto the floor over something so simple as filling the water tank and wonder no longer. Sorry if that seems a little harsh.
William Ales - good luck to you....
Winterizing Tips niftypkg Winterizing, Storage, Carports & Covers 144 01-22-2009 07:06 AM
Is Thor/AS pricing themselves out of the TT business? John Our Community 52 12-19-2002 01:02 PM
Have you ever done this?? thenewkid64 Our Community 18 10-12-2002 02:29 PM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 07:55 PM
Ammeter smily Electrical - Systems, Generators, Batteries & Solar 14 08-12-2002 09:09 PM
