Old 01-19-2007, 08:33 PM   #1
2006 30' Classic S/O
Salisbury , Maryland
pinetree
water pressure problems. Hooked up to well water with good flow and pressure. problem no pressure at shower head. HELP
Bruce H is offline   Reply With Quote
Old 01-19-2007, 10:10 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
sometimes in cold weather I'll have water flow in the back and not in the front--some small puddle in the pipes and they're frozen. You've been warm back there, but I guess it's turned cold this week? Is your shower at the end of the water line(s)?
Zep
Old 01-20-2007, 03:32 AM   #3
Water Problem
I Am Sw Ga And This Is A Problem Know Matter What The Temp.
Bruce
Old 01-20-2007, 04:02 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Have you removed the shower head & checked the water flow? There might be foreign matter in the head blocking the flow.
Or you might have a 'Water Mizer' showhead that needs drilling out.
Tom
Old 01-20-2007, 06:07 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
You seem to be saying that this occurs when you are hooked up by hose to a tap. Is the shower flow good when you are using the trailer's water pump?
How many locations have you hooked up and seen this problem? If it is just happening at home and the trailer water pump is good, I'd wonder if the water pressure coming out of the tap isn't enough to lift to the showerhead.
5 meter Langford Nahanni
Old 01-20-2007, 06:31 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Check on your shower head if it has a soap switch which turns the shower spray to a dribble while you soap up to save water. You will find this switch on the hose line right before the shower head it will look like a pin slide which you can move back and forth. Good luck.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 01-20-2007, 05:51 PM   #7
The soap switch is open. This has just started. If i fill the tank it works fine.
Old 01-23-2007, 07:04 AM   #8
1994 30' Excella
I am very happy it was something simple. Wait until to join the ranks of us vintage owners and then you can pull your hair out over some goofy problem.
Chaplain Kent
