Old 07-11-2008, 11:47 AM   #1
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
PEX vs. PVC - Which on for fresh water
I'm getting ready to set-up my fresh water system and I wanted to ask if sch 40 PVC 1/2" tubes and fittings would be acceptable for it versus copper.
I know folks like PEX but I'm curious about using PVC instead.
D
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 07-11-2008, 12:00 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We are using PEX...it's more flexible and I feel better suited for the movement in an Airstream. Our old plumbing in our '64 has some plastic fittings, but they become brittle over time and we have had to repair a couple of them. One was an elbow on the floor in a closet When we first got the trailer from a PO, it was broken - apparently from something heavy landing on top of it while traveling down the road. If you do decide to use plastic, it should be protected to prevent this sort of thing from happening...
Just my 2-cents.
Shari
Old 07-11-2008, 01:15 PM   #3
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
PVC supply lines will make the water taste like plastic.
For my GT I'm using PEX and have chosen to buy the crimper and the barbed fittings. For a fresh install, I think it is the best way to go.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 07-11-2008, 03:02 PM   #4
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Pex!
http://www.airforums.com/forums/f443...pex-29742.html
http://www.airforums.com/forums/f443...tic-29318.html
** http://www.airforums.com/forums/f443...?highlight=PVC
http://www.airforums.com/forums/f163...ded-22036.html
*** http://www.airforums.com/forums/f443...aks-22146.html
http://www.airforums.com/forums/f163...ent-17815.html
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 07-11-2008, 03:05 PM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
Good point...our supply in Maxwell is all copper, just some of the drains are PVC - some of them are brittle.
Shari
Old 07-11-2008, 03:49 PM   #6
1994 30' Excella
Mississauga , Ontario
I would use pex pipe.
One advantage could be not having a pipe burst if you fail to get all the water out.
The material gets stronger the colder it is.
Al
Old 07-11-2008, 04:10 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Interesting.
PVC supply lines will make the water taste like plastic. ...
I replace all the galvanized pipe in my first house with CPVC and never noticed a taste issue.
Last year, I plumbed 110 feet of PVC out to my Overlander's full-hook-up pad, and have never noticed a plastic taste.
I am interested to know if anyone else has noticed a plastic taste with PVC.
Tom
p.s. FWIW, I went all-copper in my refurb.
Old 07-11-2008, 05:25 PM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I've never heard mention of the taste factor. PVC is used for cold water lines outside of the house. CPVC is used for both hot and cold inside the house. My home was re plumbed with CPVC and my trailer is PEX.
Richard
Old 07-11-2008, 06:51 PM   #9
Images: 59
Even with the effects of global warming, I wouldn't use PVC anywhere the temperature could go below 30F.
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 04:14 PM
PEX pipe and the Water Heater DoorMan Water Heaters, Filters & Pumps 10 11-26-2006 08:33 AM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
