Old 03-19-2016, 03:05 PM   #29
Maniacal Engineer
barts's Avatar
Menlo Park , California
The black plumbing is under the floor; unless someone has modified the trailer, all the fresh water stuff is above the floor aside from the fresh water tank.
There were a variety of layouts; ours is a rear bath. The copper tubes for the shower went under the shower pan; the bathroom was pop-riveted together polystyrene afaict. The water pipes were also intertwined w/ the furnace ducting along the side of the trailer.
I would NOT replace the plumbing unless it either leaks everywhere, or you have the trailer apart anyway. If the trailer is coming apart, changing out the plumbing is not difficult and costs are reasonable - perhaps two or three hundred bucks in parts.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Pex or not to Pex? Isuzusweet Fresh Water Systems 24 06-21-2014 06:08 AM
To PEX or not To PEX perryg114 Sinks, Showers & Toilets 69 10-04-2012 04:32 PM
PEX Replacement CAN NOT BE DONE...'75 Tradewind... onemanclan Plumbing - Systems & Fixtures 40 04-16-2011 08:50 PM
