Old 03-19-2011, 09:10 PM   #71
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
YUP . completely LOL.
Guess I will try to eliminate the flair fitting, seems I have almost everything else I need except that one.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-20-2011, 03:43 PM   #72
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Found at Lowe's. The elbow though has threads all the way up to the end, while I needed one with the little bullet looking end. I found one in my supplies that will work. Tested the toilet, it works fine. It has 3 line which aI couldn't understand, but if you loop the plastic lines together and hook the input to the brass connector it all works. Almost have this job done....thankfully it has been as everyone here said,the hardest part was removing the old copper.
AIR #005
retired!
Old 03-20-2011, 04:54 PM   #73
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
Happy for progress
Alan, It's good news that you have had good weather to work on your project and able to get the toilet working for Springsteam. There are enough folks coming to Hawassee to keep you from going hungry. Priorities first.
GAT is offline   Reply With Quote
Old 03-21-2011, 09:58 AM   #74
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
YEA! I am s glad to finally get the plumbing almost completed. It took me awhile to sort thru all the weird different connectors I had no clue about. I know a whole lot more now.
Still gotta do the outside clean up, but that will start later. Also have to figure out what I am doing for a/c.
AIR #005
retired!
Old 04-03-2011, 06:05 PM   #75
1989 29' Excella
Tyrone , Georgia
A couple questions as my polypropylene has sprung one leak and will now be replaced.
29 foot 89 excella.
1. Where it enters fresh water tank, does this just pull out?
2. In middle ( between kitchen and closet) they run underneath to the bathroom on the other side. Is it necessary to access this from below or just feed it through from the top by connecting each to the old and pulling it through?
mikeandnora is offline   Reply With Quote
Old 04-19-2011, 11:36 AM   #76
1977 31' Excella 500
Prescott , Arizona
PEX barbed fittings and hose clamps
Has anyone tried using just hose clamps to secure the PEX pipe on barbed fittings instead of the crimp rings?
Personally, I can't see the crimp hose clamps providing much more force and the hose clamp would be removeable.
Thanks....
walstibsf is offline   Reply With Quote
Old 04-19-2011, 11:46 AM   #77
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thanks....
I have used hose clamps on pex pipe with barbed fittings in temporary situations. It did not leak.
However, I think this would void the manufacturers warranty on the pipe. I would not use a hose clamp and cover it up in a wall. Anyway, the crimp fittings are cheaper and faster once you have the tools.
Old 04-20-2011, 07:40 AM   #78
1975 29' Ambassador
Reno , Nevada
Pex is usually a bit stiff for hose clamps to be effective.
Crimp is OK for manufacturing where you can set up a jig and the capital cost of the tools is minimal compared to the other costs in the run.
For repairs and in-site replacement where just a few joints are involved (such as re-plumbing a trailer, fittings such as the Flair-It found at most corner hardware stores or iplumb.tv work well. The *byte are also OK but they tend to be more costly, more bulky, and don't have a definitive grab.
The Flair-it fittings have a barb on the inside of the pipe and a nut used to crimp the pipe down on that barb. They are easy to use and can easily be tightened or removed and re-used.
Old 04-20-2011, 08:10 AM   #79
1989 29' Excella
Tyrone , Georgia
Does anyone know if I was doing something wrong? I used the $30 clamp from home depot that has multiple sizes and when clamping down the brass ring on 1/2 inch is was ridiculous. I'm pretty strong and using a 10 inch channel lock did not tighten it up enough. I literally had to put pipes on the end of the handles to get about 20 inches of leverage to get them to "go".
Mike
Old 04-21-2011, 03:56 AM   #80
1988 34' Excella
Orlando , Florida
fishandfly - Try using vice grips next time - much easier.
Mike Eagle is offline   Reply With Quote
Old 04-21-2011, 08:46 AM   #81
GlobeTrottin's Avatar
1964 19' Globetrotter
Chelsea , Michigan
The "pocket crimper" is all I have ever used. I have a dedicated Vise Grip (the real thing - not a knock off) that is in my Pex bag and have never had a failure. It admittedly gives even the Vise Grip a workout to get a "go" instead of a "no go" on the test gauge but I have had all kinds of fun with Pex since I got those tools. Even put Pex (1/2" shoved inside 3/4" to make a stiff 18" rod) "poles" on my fishing boat trailer as guides so the boat slides right up the middle when loading from the lake. Works like a charm.
GlobeTrottin is offline   Reply With Quote
Old 04-21-2011, 09:52 AM   #82
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
This is a great thread. A great resource for my future PEX project.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-21-2011, 11:06 AM   #83
1989 29' Excella
Tyrone , Georgia
I tried a vice grip (8" I think) and it was clearly too little leverage.
What size of vice grip do you use? Also, why does a vice grip help at all over a channel lock? I would think the pressure needs to be applied at one instant to crimp it down. I wondered that when I saw the vice grips being used on the package too.
Thanks!
Old 04-21-2011, 12:05 PM   #84
Chelsea , Michigan
I think I have an 8" Vise Grip that I used with the Pocket Crimper. I have noticed that when I put the crimper pieces together and squeeze them by hand down onto the copper crimp ring, they can be squeezed together so that the crimper just "hangs on" even if I let go to pick up the Vise Grip. Then the Vise Grip gets a squeeze, and sometimes let go, twist a bit on the adjustment to tighten, and another squeeze. That does the trick, we get a green light GO from the test gauge and it's on to the next one.
master list of caravans? NJtoNC Airstream History 4 01-03-2010 07:22 PM
Vendor List & Information list-pass it on! Mrwaterway General Repair Forum 20 12-09-2009 01:22 PM
Pex Parts List? Hind-Sight Fresh Water Systems 5 08-30-2006 06:33 PM
The master plan till Our Community 0 01-26-2004 03:41 PM
