Old 11-16-2010, 10:32 AM   #43
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks. So the manifold might look cool but it's not needed. I intend to get 1/2" tubing.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-16-2010, 06:31 PM   #44
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
Started Pex replacement today
Restoring my 1976 and this week put air to check for leaks. Wouldn't you know the previous owner didn't winterize so I found several splits.The main one was close to the tub mixing valve and naturally difficult to get to. Decided to replace the valve and fish the new pex in.Took most of the day because you can't get to anything. It was difficult but forced me to do the rest. If any one watches the Christmas story the guy working on the furnace with bad words may sound like me. We will see how this goes.
GAT is offline   Reply With Quote
Old 11-16-2010, 08:06 PM   #45
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
AlanSD
I would stick with PEX and Ts. Keep it simple. When I pressure tested the Bambi, all the leaks were in the brass PEX to MIP or FIP fitings. All the crimp rings on the Pex were perfect.
Tim
Beaker63 is offline   Reply With Quote
Old 11-17-2010, 12:48 PM   #46
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks Tim. Looks like I can order what I need for this job in a month or so. Getting the floor repair and outriggers done first.
AIR #005
retired!
Old 02-04-2011, 03:39 PM   #47
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Pex manifold
Can I use a copper Pex manifold that has a 3/4" input and 5 of the 1/2" ports? It is mainly the 3/4 input line I am wondering about.
AIR #005
retired!
Old 02-04-2011, 04:06 PM   #48
Rob&Julie's Avatar
1988 32' Excella
Bonny River , New Brunswick
Images: 16
Originally Posted by Aviator View Post
Pardon my lack of knowledge, but what is "heat trace tape"? I was thinking of insulating my runs with the foam sleeves.
Not sure if you received an answer. its a ribbon type "heater" that you wrap around your pipes and plug in. there normally is a thermostat connected that turns the system on at freezing temps. it would mean that your trailer would have to be connected to power all winter though.
Rob&Julie is offline   Reply With Quote
Old 02-05-2011, 07:31 AM   #49
GAT
GAT's Avatar
1976 31' Sovereign
Pex manifold
Alan, I hope all is going well with your pex replacement. just a suggestion. I wondered about using the pre made manifold. As I got into the process. And ran the various hot and cold runs back to the rear access so I can see any joint leaks I decided against using the manifold and made one out of lots of tees and put the connections where I needed them. The 3/4 inch in and out cause too much connection problems for me. Also you want one output to be horizontal to the drains so everything drains out. I took ours to Fort Mountain last weekend for the first time out to check all plumbing and everything worked well. Good luck on your project.
Old 02-05-2011, 07:50 AM   #50
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
GUESS I asked the manifold question twice. Sorry. Saw a 3/4 in with 5 1/2 outs and figured it might be a simple set up, its about 10 bucks.
I am ready to start putting inthe pex, got both faucets set in place.
AIR #005
retired!
Old 02-05-2011, 02:33 PM   #51
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by Beaker63 View Post
AlanSD
Tim
anything special to look for in crimping rings and tool? I see copper rings available pretty cheap. If I buy a bunch of tees and rings it will sure be less than going with all shrkbite connectors. $$ is an issue right now
( I mean always..)
AIR #005
retired!
Old 02-05-2011, 02:47 PM   #52
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
( I mean always..)
Alan,
I bought a crimping tool from Lowes that has 3/8,1/2, 3/4 and 1 inch rings. It was around $100 but got it on sale for less than$75. May have been a close out model. I have only used the 3/8 and 1/2 but I like it a lot and never have to do over. The shark bites are expensive and I only use those types when going from the PB to Pex. I'm looking to buy a bunch of couplers, tees and elbows so I can quit going to Lowes to buy. HD rarely has any Pex in there mess for Pex. I want to transition out of the PB as soon as I can and also need to do some water lines around the shop. If you find a good source for the fittings, let me know.
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 02-05-2011, 03:41 PM   #53
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I am an Ebay nut and I see lots of Pex stuff on there. Often the crimpers for 20-30 a piece and the fittings in lots at good deals. Usually someone who bought too much, or a dealer who sells close outs. I went to HD just now and they are pretty limited on what they have. The guy told me to stick with the brass connectors, and try to do as many connections as I can beforehand. I did not think of crimping on short lines for the faucets, inserting the faucet body and then attaching the tee from below. It shows just how much of a newbie I am for plumbing. DUH
AIR #005
retired!
Old 02-05-2011, 07:29 PM   #54
GAT
GAT's Avatar
1976 31' Sovereign
Alan, Go to Lowes for most of your things if not on EBay. They have more things for pex.Some things you may want to consider. In doing my 1976 this is some things I found.Lowes has--1/2 inch pipe with tabs used for shower heads that screw to the bumper for the inlet when you put a garden hose fitting. 1/2 inch pressure reducer,1/2 inch check valve,1/2 inch pop off valve. HD doesn't. 1/2 inch pipe that hand tightens to faucet end and hot water fittings. Kolbot tools makes a pinch clamp tool instead of using compression rings, They get in closer and I didn't have any leaks.I used the toilet cut off valves to make the low area drain and two sink supply lines through the bottom . you need a line from the pop off valve incase over pressured. Buy contractor packs of tee as it takes quite a few. Lowes has a better selection of brass instead of black or galvanized While you're on a roll add a valve and hand sprayer in the back to rinse feet at the beach. Soon I will try to learn how to add pictures and some of this may made since
Old 02-06-2011, 07:35 AM   #55
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Photos here
thanks for all the pex info. To add photos to your posts, go below where you type and look for the attach files box, with the grey button that says manage attachments.It is down below the submit reply and preview post buttons.
After you hit the button to manage attachments, a new little window opens where you can "browse" through your computers files to find the pictures. Then select one at a time, and hit upload when through. Close the little window and post your message.
The files can be reasonably large- the sizes are listed when you hit the manage button.
AIR #005
retired!
Old 02-09-2011, 11:53 AM   #56
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I ordered a bunch of fittings: tees, couplings,elbows, crimp rings. All from Pex Universe.
Their prices were less than half of what I found at Lowe's. Home Depot had little if anything at the one near my home.
I will buy the tubing at Lowe's or HD, and use a few gator or shark bite or whatever they have fittings for the water heater.
Now i need a crimper. Saw one hand made by a seller on Ebay that looks promising. Lifetime warranty from him also and many sold.
Ready to get started as soon as the weather is a tad warmer..
AIR #005
retired!
master list of caravans? NJtoNC Airstream History 4 01-03-2010 07:22 PM
Vendor List & Information list-pass it on! Mrwaterway General Repair Forum 20 12-09-2009 01:22 PM
Pex Parts List? Hind-Sight Fresh Water Systems 5 08-30-2006 06:33 PM
The master plan till Our Community 0 01-26-2004 03:41 PM
