Old 10-28-2010, 11:02 AM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by Aviator View Post
Alan, When you finish the project, would you please post a list of material used?
will do . I am ordering a marine type hose inlet to mount also. I hate the hose hanging out of the trailer. Looks like the I will buy is 1/2 " pex tubing with Sharkbite connectors ...Maybe a small manifold but I figure less than 10 connections total. I am guessing all the sinks take 3/8 connetions?
2 Kitchen 2 bath faucet, 2 shower, 1 toilet, 1 water heater, maybe 1 outside water.
I will be sketching this weekend while I pull out my old Dometic fridge.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-11-2010, 08:54 AM   #16
j Z
1979 23' Safari
Great Falls , Montana
I plan on doing PEX in my trailer as well. I did my entire house in PEX and it is a great system. Instead of buying both red and blue to hot and cold runs, I bought red and blue electrical tape and put a band on the fittings to distinguish them. That way I only had to buy 100' rolls of white pipe in each size. For making tight curves, use one of the plastic braces or a 90 for tighter curves around the water heater, etc. My house system has very few fittings, just a few manifolds with direct runs to each fixture. It makes for a very quiet and efficient system.
I went with Uponor fittings for my house and bought the expander tool for $300. I would consider selling it after my projects are done, if ever. FWIW the Uponor tools sell for 90% of retail on eBay.
Anyone use heat trace tape on their pex to keep everything warm in winter?
Has anyone installed an on-demand water heater such as the Girard?
Cheers,
JZ
j Z is offline   Reply With Quote
Old 11-11-2010, 09:06 AM   #17
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Pardon my lack of knowledge, but what is "heat trace tape"? I was thinking of insulating my runs with the foam sleeves.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-11-2010, 11:25 AM   #18
Crusty's Avatar
1992 34' Excella
The Quick-Cinch clamps available at Lowe's for use with PEX and brass barb fittings work great (better than the copper rings) and the crimpers for them are affordable (~$40). They also stock a clamp remover if you need to try again because you weren't paying enough attention and poorly cinched a clamp.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 11-11-2010, 11:42 AM   #19
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Does anyone know how to test your water lines to make sure there are no leaks after you run new PEX? I used the Sharkbite fittings and want to make sure all the connections are good before I put everything back together.
adwriter73 is offline   Reply With Quote
Old 11-11-2010, 12:20 PM   #20
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
good info guys ...
AIR #005
retired!
Old 11-11-2010, 12:51 PM   #21
Crusty's Avatar
1992 34' Excella
You could always pressurize your assembly with compressed air (50 psi or less) and squirt a soapy water solution on each connection and look for bubbles. The way that plumbers test a system is they install a very sensitive pressure guage in the system and pressurize the system with air and valve it closed and then they come back and look at the pressure guage in 24 hours to see if it has dropped any.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 11-11-2010, 04:56 PM   #22
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Good idea. I'll see if I can get a plumber to come out and check it for me.
Old 11-12-2010, 09:19 AM   #23
j Z
1979 23' Safari
I never tested anything. Just pressure up your system with water and look for leaks. If using an expander tool such as the Uponor that I have, wait 10 minutes for all the connections to relax and get a good bind on the fittings. If you have crimp-on fittings or sharkbites, no wait necessary. Of all the fittings I did in my house, I had only one leak. It was redone and no problems after that. PEX is very easy to use and it is very unlikely to leak. The hardest part of my PEX work was having to sweat a few copper fittings to connect to my main supply and to the sprinkler system.
Old 11-12-2010, 12:49 PM   #24
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Timely information. Thanks.
Does anyone know, or have any info on the effects of heat on the PEX tubing?
This winter’s project is to rebuild the sink cabinet and fix the plumbing mess jammed in the back corner. The lines run under the furnace.
Yesterday I tested the "new" NT-30 and it gets really hot at the outlet, right above the pipes. The lines also make a sharp "S" curve to come up off the floor and run along the ductwork to the water heater and fixtures in the back.
What do you think? Keep copper in that location or run the PEX straight through. Does the PEX tubing have a memory? Could it be heated with a hot air gun until pliable and then formed to the "S" curve?
I’ve got plenty of time to figure this out, but with an open thread I thought I’d toss this out and see what sticks.
Tom
Name:	Sink Cabinet Removal 037a.jpg
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 11-12-2010, 01:29 PM   #25
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Pex won't bend that sharply. For a pex bend that tight I think you would have to use 2-L's.
If you are using crimp connectors ( I did ), make up your joints as a dry fit and mark the orientation of the fitting and the tube with a sharpie. The fittings tend to turn a little when you are getting the rings in the crimper and that will cause problems with alignment. In fact, I found that if you mark the fittings, put a copper ring on and just lightly crimp it with a pair of pliers, it will stay where you want it as you put the big crimp tool over the rings.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-12-2010, 05:35 PM   #26
2011 27' FB Flying Cloud
Bradenton and Saluda , Florida & North Carolina
Small leak in new unit!
This is a timely thread. On the road after picking up our new 2011 27fb Safari. This trailer is such a beautiful thing, airstream has stepped up. There is just one small thing, there is a small leak in the bathroom behind the toilet. AS used pex without the copper pex fittings. When I use water from either sink, there is a leak that puddles behind the toilet.
How do I go about fixing this? Can I recrimp the clamps?
I love this trailer!
Nancy
Ps will post new pics of unit in my first post "we did it" after I get home and settled!
ncbambi is offline   Reply With Quote
Old 11-12-2010, 05:37 PM   #27
Made a typo. AS used pex with copper compression fittings (not without the copper fittings) in last post!
Old 11-12-2010, 06:21 PM   #28
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
pex to fresh water tank
I will also embark on the plumbing journey this weekend. I have 1/2" PEX, Sharkbite fittings, and a polyethylene fresh water tank.
Do I need to use plumbing tape (pipe tape) on the male Sharkbite fitting that will go into the threaded female tank outlet?
Thanks.
SpaceEgg is offline   Reply With Quote
master list of caravans? NJtoNC Airstream History 4 01-03-2010 08:22 PM
Vendor List & Information list-pass it on! Mrwaterway General Repair Forum 20 12-09-2009 02:22 PM
Pex Parts List? Hind-Sight Fresh Water Systems 5 08-30-2006 07:33 PM
The master plan till Our Community 0 01-26-2004 04:41 PM
