Old 03-21-2014, 01:42 PM   #1
Phodeaux's Avatar
1998 34' Excella 1000
2010 25' FB Flying Cloud
San Jose , 95136
Pex Loop...
I am in the process of repairing some freeze damaged pipe and found a loop of Pex installed by a local Airstream dealer. It is located next to the water heater and I am wondering if it is necessary? I was about to remove it but wondered if it served some important purpose. I think it is cold water, hot marked with red...
Phodeaux is offline   Reply With Quote
Old 03-21-2014, 01:52 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Is there a one-way valve in the loop? Some outside faucets are set up that way, so that the hand valve turns off the faucet but still allows city water to come in.
Old 03-21-2014, 02:17 PM   #3
Phodeaux's Avatar
San Jose , 95136
Good point! This is on the source from the pump so it may have a check valve in the loop. I guess I had better leave it in place. Thanks for your help! I knew this would be the place to find the answer!
Now, can you tell me how to get three or four hands behind the toilet and under the water heater to replace the pipe? ;-)
Old 03-21-2014, 02:21 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
1) start by getting a basin wrench
2) try removing large assemblies and fixing them where there's room, then putting them back
Old 03-21-2014, 03:39 PM   #5
1974 Argosy 20
Kooskia , Idaho
I would guess it is part of a made to fit water heater bypass system so the water heater is out of the loop when RV antifreeze is put in for winterizing.
Old 03-21-2014, 03:40 PM   #6
1994 30' Excella
Mississauga , Ontario
It is possible that the line without the valve has a pressure reducer in it. By closing the valve in the parallel line you would control water pressure. Mine has something like that.
Al
Al and Jean
TAC ON-3
Old 03-21-2014, 04:56 PM   #7
Phodeaux's Avatar
San Jose , 95136
Lots of good ideas! I think the pressure reduction option makes sense as there seems to be a strange "thing" in the loop... In any case, I left it in and fixed the leaking fitting.
Now there seems to be another leak at the toilet connection! I disconnected the toilet and it leaks when I reconnected it! I am constantly reminded why I don't like to get into this stuff!
Mice like pex...oh no! Flynavy Fresh Water Systems 10 01-09-2012 08:31 PM
Leak at brass elbow in pex line behind toilet Goal15 Sinks, Showers & Toilets 3 11-19-2011 09:32 PM
PEX crimp vs. press on Sharkbite experiences idroba Fresh Water Systems 17 08-31-2011 10:15 AM
PEX Replacement CAN NOT BE DONE...'75 Tradewind... onemanclan Plumbing - Systems & Fixtures 40 04-16-2011 09:50 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 05:10 PM
