Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-29-2008, 06:36 PM   #29
Profile:  Currently Looking...
johns island , South Carolina
Pex is far superior. Make sure you use copper or brass fittings and connections. Also, be aware that all connections are interior to the pipe, and therefore you functionally loose one pipe size. We have ( in the construction business ) found that installing 3/4" pex instead of 1/2" gives us the equivilent water pressure.
davechili is offline   Reply With Quote
Old 11-09-2008, 03:29 PM   #30
Profile:  Cedar Creek , Texas
I re-plumbed my OTAS with PEX after a kitchen remodel and used Seatech fittings. These fittings do not have a barb inside the pipe and do not reduce the ID at the fitting.
Pressure tested (air over water) at 150 psi when installed and now at 14 mos and 10 trips since installed I've not experienced any leaks period.
No tool required and easy to remove/reuse the fittings.
Quick Connect Fittings - Manifolds - Valves - Sea Tech, Inc.
Centex is offline   Reply With Quote
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 08:34 AM
Kichen remodel - 85 Sovereign 25' j54mark Cabinets, Counter Tops & Furnishings 6 10-14-2003 07:20 AM
85 Sovereign 25' j54mark 1985 Sovereign 7 10-30-2002 10:23 PM
1978 AS Sovereign and doing my own repairs JLD Our Community 2 09-05-2002 12:28 PM
Help with Ancient Sovereign patti 1956 Sovereign 2 06-06-2002 03:23 PM
