Old 02-15-2011, 11:29 AM   #1
Aluminatic
wworx's Avatar
1966 20' Globetrotter
Norwell , Massachusetts
PEX Diverter??
Starting to plan the fresh water system for our refurb and plan to use PEX. I've been looking for a simple "T" diverter to use with PEX so I can make a simple bypass of the water heater when winterizing, but I haven't been able to locate any PEX fitting like that. Has anyone either found one or come up with a simple in-line PEX based diverter / bypass scheme?
___________________________
Greg & Mary
Take the high road... the return trip is easier.
Trotterworx - Refurb of 66 Globetrotter BLOG -
http://trotterworx.blogspot.com/
TAC MA-7
wworx is offline   Reply With Quote
Old 02-15-2011, 11:48 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Tee's
"Flair It" has Tee's for Pex tubing. I used "Flair It" fittings through out my trailer. There are photos on my blog.
Old 02-15-2011, 12:00 PM   #3
Aluminatic
wworx's Avatar
Thanks, I checked and they do have "T"s but not diverter or valved "T"s. I'm looking for something that will allow me to direct the flow in one direction (water heater) or the other (bypass). Had this setup in an SOB and liked it. I think it was PEX on that. Just can't find the fitting now.
Alternatively, thoughts on another, simple bypass setup I could do with all PEX would be good to.
Greg & Mary
TAC MA-7
Old 02-15-2011, 12:24 PM   #4
x
XXXX , XXXX
greg is this what you need.
http://www.escousa.net/cgi-bin/miva?Merchant2/merchant.mv+Screen=PROD&Store_Code=E&Product_Code= 16910&Category_Code=SWV1
wasagachris is offline   Reply With Quote
Old 02-15-2011, 12:31 PM   #5
Aluminatic
wworx's Avatar
BINGO! Thanks! That'll do it for what I wanted. Now that I know what to call it I've found a few options. Awesome!
Greg & Mary
TAC MA-7
Old 02-15-2011, 12:53 PM   #6
x
XXXX , XXXX
Greg IMO I would use flair it fittings for the whole system. I have used them for several repairs to SOB's and are easy to install. If you ever have a problem they are easy to remove and replace either the fitting or the line. They however are more money. Also but the tool to tughten the nuts. They can be tightened with pliers in a pinch but the tool does a better job and works great in tight spots.
Old 02-15-2011, 01:28 PM   #7
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
HD and Lowes carry brands that are similar to shark fitting. They are a slide on with teeth that hold, and they can be removed just as easily.
robwok is offline   Reply With Quote
1968 Avion C11 Truck Camper restoration jforb Vintage Kin 310 01-04-2016 06:20 AM
'74 Excella Rebuild - The new chassis DanielB 1973-1974 Excella 500 359 11-04-2013 02:02 PM
Pex master list ALANSD Fresh Water Systems 86 04-22-2011 07:57 AM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
