Old 08-03-2006, 08:54 PM   #15
1963 19' Globetrotter
Moline , Illinois
So far so good
I've had the fittings in for 14 months and 12,000 miles with no problem. Whenever I can , I like to use anything marine that will work on my trailer. To me it seems like the boating industry (especially the higher end boats) use the best quality of part that they can find so that it will stand up to a harsh environment and lots of vibration.
63air is offline   Reply With Quote
Old 01-26-2007, 06:37 PM   #16
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Originally Posted by Dano57
As I enter week 3 of Airstream ownership I have decided to repair a couple of leaks in the water system by re-plumbing the entire system. I am going to go PEX but can't decide whether to go crimp or use the fittings by Flair-It. What are your opinions?
I guess from what I understand there are 2 different crimping systems, the black crimp ring and the Oetiker stainless steal Crimp ring, so what are the pros and cons?
If fittings are the way to go should I use the white Flair-IT or the black Flair-It Plus?
So many questions....
Dan
You should check out shark-bite fittings they will not crack with all of the viberations.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 01-27-2007, 11:55 AM   #17
1969 27' Overlander
Colorado Springs , Colorado
Compression all the way
Like many others here I am redoing entire A/S (69 LY) with red and blue pex. If you have room the Big Orange Box's grey quest compression fittings work great. I like the ability to slowly put it togeather and make adjustments as I go. In other word I almost never get it right the first time. The pvc compressions are forgiving to use and easy. one point don't over tighten that can cuase problems. Good luck
Deano.
Deano69LY is offline   Reply With Quote
PEX in the Sovereign Zeppelinium Fresh Water Systems 29 11-09-2008 02:29 PM
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
Pex questions Bradjun1 Fresh Water Systems 20 05-15-2006 10:53 AM
Cost: PEX vs Copper TomW Fresh Water Systems 5 04-13-2006 06:15 AM
