Old 11-06-2010, 08:36 AM   #1
1966 22' Safari
Davis City , Iowa
Pex behind the stove
Hi,
I re-plumbed my 1966 safari with pex and am now wondering if I should insulate or isolate the pex that lies behind the stove area. Any thoughts or suggestions? I can't believe it's almost completed.
drowe42 is offline   Reply With Quote
Old 11-06-2010, 08:51 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
How much clearance?
We did the same job with our 1966 22' Safari, and we didn't insulate the PEX or isolate it any more than the original tubing. If I remember correctly, the water lines we took out of that area were rubber tubing--probably less heat-resistant than the PEX. Also, there is some distance between the back of the stove and the area where the water lines run.
We'll see how this works. Have only used the stove a couple of times since the water system rebuild, and the oven only for some quick batches of toast.
Glad to find another '66 Safari owner on the forums!
Old 11-06-2010, 11:18 AM   #3
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Pex is rated at 200F, so I don't think that there is any problem behind the stove.
I'm planning to replace the polybutylene plumbing in my '94 Sovereign with pex, I do plan to insulate the hot water lines, and also use the foam insulation in areas where the tubing may rub against stuff.
snake is offline   Reply With Quote
How much PEX Aviator Fresh Water Systems 4 08-23-2010 09:05 AM
PEX in the Sovereign Zeppelinium Fresh Water Systems 29 11-09-2008 02:29 PM
PEX Conversion Sundance Fresh Water Systems 18 07-12-2007 04:12 PM
Re-plumbing 1/2 or 3/8 PEX Boondocker Fresh Water Systems 5 03-04-2007 08:52 PM
E-PEX tubing Pahaska Fresh Water Systems 3 03-03-2003 12:03 PM
