Old 11-05-2006, 08:22 PM   #15
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
We are doing a complete re-plumb on our 79 Excella and used PEX with the Flair-It connections. The mid-west distributer is here in town and they convinced me to use the fittings verse crimp rings. They also had the white tubing with red or blue logos along it so you could distinguish hot and cold lines.
The flair-it connections, when made up are very solid. I made one up and then tried to take it apart and although you can remove the nut holding the line, the line itself seems to seat on the barbed end of the fitting and is tough to remove. They make a special wrench to tighten the fittings with, seems like it was around 10 dollars and well worth it.
One last thing, the supplier told me that PEX has a thermal memory and if you heat it it will turn clear, remove the heat and hold it in the position you want and when it turns white it will retain that shape. My father-in-law did much of the plumbing and by using a heat gun made some impressive radius's and formed the PEX around various obstructions.
Dan
Dano57 is offline   Reply With Quote
Old 11-06-2006, 09:57 PM   #16
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
Greetings,
Just a thought on the rings vs. compression fittings. I have used, and still use if necessary, Oetiker clamps. These are the small, eared clamps that require a specialized plier. The pliers are available for well under $40 and are designed to install the clamps. I bought mine here. One advantage of the pliers is that the pliers have two clamping faces allowing for some very tight installations to be accomplished quite easily.
This link will give you some info on the clamps and why you might consider them as an effective, low cost alternative to the screw together compression fittings. A big plus is the ability of the clamp to 'give' a little when the PEX pipe and fitting are under freezing pressure and return to full functionality when temperatures return to above freezing.
Just a thought.
Take care,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 11-06-2006, 11:00 PM   #17
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by soldiermedic
The hardware store sells PEX in red and blue but they only sell in 100 foot rolls. I was going to buy a 50 foot roll of the white, but would love colored lines for ease of future work. Does anyone have leftover tubing that they are looking to sell?
I bought my entire water supply piping and fittings here:
www.rvpartsoutlet.com
The flair-it fittings and pex ( poluethylene tubing) is quite easy and effective to work with.
I did not mind paying a little more for an excellent system that is flexible enough to make changes later if neccesary. I did buy the " special tool' for 4 5.00 to tighten the flair-it fittings.
I did not have a single leak from the flair it to pex fittings. I did have a few drips from the flair-it to water heater inlets due to insufficient teflon tape application.
Uwe
www.area63productions.com
Old 11-07-2006, 05:58 AM   #18
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
What price did you get?
I would split it with you perhaps.
'77 Sovereign Intl 31' CB
Old 11-07-2006, 07:47 AM   #19
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
I had the same dilema-I went with Sea Tech/Watts and have no regrets
trevisgardne is offline   Reply With Quote
Old 11-07-2006, 08:13 AM   #20
soldiermedic's Avatar
Florissant , USA
The 100' rolls of red and blue are $25.00+tax each. I figure I need maybe 50 feet total combined.
soldiermedic is offline   Reply With Quote
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
