Old 11-19-2007, 10:57 AM   #1
Lothlorian's Avatar
Loganville , Georgia
Overlander '73/no Fresh water tank
I am a first time RV owner. Not knowing much about RV's I was happy with the fact it is in great shape in and outside. What I have come to realize is they changed the RV to only excepting water from the outside. Lines have been cut, flex pipe has been put in and I do not know where the water tank is located or what it looks like. I don't have an owners manual to go by. Can anybody please tell me what the dimensions are for this type of tank, where I can get a replacement, and where does it go? JPG pics are great also.
SIU Bound
Lothlorian is offline   Reply With Quote
Old 11-19-2007, 11:00 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Your fresh water tank should be about 45 gallons in capacity, and mounted between the frame rails just ahead of the front axle. The chrome-looking cover on the curbside of your coach, usually directly under the 120 volt outlet cover, should be the access hatch for fresh water fill. It is locked by a key.
Old 11-19-2007, 11:53 AM   #3
Lothlorian's Avatar
Thanks a bunch!
Thank you for such a quick response and I will check it when I get home.
SIU Bound
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
69 Overlander water tank swap colin57 Waste Systems, Tanks & Totes 2 04-24-2011 08:23 PM
