Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 07-21-2007, 12:32 PM   #1
Antique Pedaler's Avatar
Profile:
Airstream Registry
Overflows & Overflows
Reading some of the "overflow" posts suggests I tell you about my recent experience. While on city water, backflow through the water pump would fill the freshwater tank and overflow out the breather tube. Also when boondocking, the water pump came on for a short burst every five minutes or so.
When we got home I called the manufacturer, Aquatec. The customer service tech figured I had a faulty check valve and sent me a new one. When I opened the water line at the pump outlet to remove the suspect check valve....there was none there. I installed the one sent to me and I think everything is okay now. But the long term test will come with an upcoming month long trek.
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup
X '99 27, X '05 19, X '07 23
Santana, and Ventana Tandem bicycles
Hobie tandem Kayak
Antique Pedaler is offline   Reply With Quote
Old 07-21-2007, 12:37 PM   #2
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
jcanavera also had a faulty check valve. Replacement seemed to also fix his similar issue (though you didn't even seem to have one).
Our pump may come on 1 time every 5-6 hours of so if that, but I agree, once every 5 minutes it way too often.
Old 07-21-2007, 01:45 PM   #3
ScottW's Avatar
Profile:  2007 30' Classic
Hernando , Mississippi
When hooked up to city water, my fresh water tank has slowly lost volume (yes, the pump is off). Is this a check valve problem? It is on a 2007 Classic.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 07-21-2007, 04:48 PM   #4
Profile:  2007 25' Safari FB SE
Burien , Washington
You might check the drain valve on the bottom of the fresh water tank. I sure can't imagine why being hooked up city water would drain the fresh water tank, other than a venturi effect taking place.
SRoffe is offline   Reply With Quote
Potty overflows in the night! silverpeanut Sinks, Showers & Toilets 33 08-16-2007 03:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
