Old 07-17-2016, 08:18 AM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Overflow valve?
Is this an overflow valve on the top of my freshwater tank? Or should it NOT leak when the tank is full? Click image for larger version
Name:	ImageUploadedByAirstream Forums1468765072.185317.jpg
KYAirstream is offline   Reply With Quote
Old 07-26-2016, 03:43 PM   #2
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
This is not a valve . I think this is an inspection aperture.
Greetings from Switzerland - Werner
Cruiser6483 is offline   Reply With Quote
Old 07-26-2016, 04:35 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
That is a plug from the manufacturing process. It should be watertight. It sounds like yours has failed.
TheGreatleys is offline   Reply With Quote
Old 07-26-2016, 07:17 PM   #4
Thought as such, so I sealed it up tight.
Freshwater Overflow Geyser RevBec 1990 - 1993 Excella 5 04-19-2015 12:33 PM
Looking for raidiator overflow container for 1989 345LE ahmarquis8 Mechanics Corner - Engines, Transmission & More... 3 02-12-2006 08:13 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
Overflow hose in freshwater tank is loose. TBKP's Overlander Fresh Water Systems 1 08-03-2003 08:46 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
