Old 06-14-2007, 03:45 PM   #1
2004 22' International CCD
woodland park , Colorado
overfilled water tank
I should never volunteer to do the jobs better left to my husband...but I was just trying to be helpful. I put the fresh water hose into the fresh water tank to fill it and walked away for just a few minutes (really). Previously,when I watched my husband fill the tank the hose would pop out once the water pressure built up in the tank. It didn't do that this time. When I went back to the trailer I pulled the hose out of the fill spout and water shot out of it like a fire hydrant. I was stunned. I walked around to look inside and the floor of trail is bulged up about 4" high in a ridge that travels across the floor from the door to the kitchen. It seems the tank is balooned, but not leaking. There is one leak that I can see coming out of a low valve under the trailer. What do we do? The flooring is not broken or cracked, but I imagine we will have to replace it? What about the tank? PLEASE HELP!!!!!
sadiek is offline   Reply With Quote
Old 06-14-2007, 03:51 PM   #2
ScottW's Avatar
Hernando , Mississippi
The thought of getting really drunk and having a good cry comes to mind, but I'm sure you want/need a more mature input to your question. Help, someone!
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-14-2007, 04:01 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Yee-ouch! I use a Camco E-Z Fill for my fresh water. The tank filler on my '06 won't let me thread a hose into it. Does yours? How else could you build up so much pressure?
5 meter Langford Nahanni
Old 06-14-2007, 04:06 PM   #4
gparker's Avatar
1970 31' Sovereign
Denham Springs , Louisiana
Open the grey water drain and turn thr water on. Let it run for several minutes until the over-fill situation is resolved. I don't understand how the tank does not "vent "itself through the filler spout though.
Greg
Greg, Ashley, Olivia, and Jane Ashley
AIR # 13681
gparker is offline   Reply With Quote
Old 06-14-2007, 04:11 PM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Lucy.
Sounds like something that would have happened to Lucy.......or even Robin Williams. Sorry.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-14-2007, 04:55 PM   #6
An over filled water tank that is mounted underneath the floor can and will place tremendous pressure if it expands beyond it's original design or within an enclosed cover or box.
You will need to remove the tank and inspect the underbelly area. More than likely a frame cross member has become bent, holding the pushed up floor in place.
The framing will have to be fixed before you can correct the floor.
Old 06-14-2007, 05:26 PM   #7
FreshAir's Avatar
1966 24' Tradewind
I am so sorry to poke fun of your mishap in my post 'Lucy'. After what Andy posted I did not 'think' there may be such consequences other than a relief valve replacement. Hopefully your husband realizes that it could have been him forgetting the water. Obviously there is a serious defect somewhere that would not be evident until your awful experience. May your repair be not as serious as it sounds. Again, my appologies for my conduct and for what happened. Please stay with the Forums. That will be the best thing that happened to you today.
Neil and Lynn.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 06-14-2007, 05:37 PM   #8
2005 22' International CCD
Woodland Park , Colorado
Hi. This is the husband. Just got home and looked at it. I would say the water tank is definitely gone. It is severely bulged out below and above, where it has pushed up the floor.
The floor is cracked and will eventually have to be replaced. The more immediate concern is the water tank, which definitely will need to be replaced. Can comeone give me an idea how difficult this is? Initially it does not look too difficult, but looks can often be deceiving. Also, what else do I need to look for?
Finally, are these tanks proprietary or is there some kind of standard? The Airstream dealer is closed right now so I was not able to get a price quote but I know most anything Airstream is going to be expensive....
I have about a month to get this fixed as I will be departing on a work related trip and living in it. Any help would be much appreciated! Thanks, jk
JK3500 is offline   Reply With Quote
Old 06-14-2007, 06:54 PM   #9
All recent vintage Airstream tanks are special for Airstream.
The water tank costs a little over $100.00 plus shipping. If you need the tank pan, it costs almost $150.00 plus shipping.
It it wise to remove the pan and tank, so that you can get a first hand view of all the damage.
You may not need a water tank, but you certainly will need some steel chassis parts.
Old 06-14-2007, 07:09 PM   #10
thanks for the info andy. the tank does not look hard to remove. i was able to push the floor dow to where it is now almost level, with only a slight bulge. the wood underneath the linoleum is obviously cracked.
however, we were planning on taking a short trip this weekend. right now thinking about still taking the trip (to crested butte), just without water, and surveying the damage when we return. question is, did the trailer likely sustain any structural damage from the tank bowing out or should I be ok for a short trip?
also talked to my insurance company and they are sending an appraiser out to determine if it is a claimable loss. hopefully so, as i am sure replacing the floor will be pretty extensive (and expensive). we'll see... jk
Old 06-14-2007, 07:12 PM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
One suggestion moving forward is that you fill the tank very slowly. The fact that you said it took only minutes concerns me. My 39 gallon tank takes about 15-20 minutes to fill...sometimes a bit more, sometimes a bit less. The vent hole if you look at it, is far smaller than a garden hose. If the faucet is on full or more half, more water gets into the tank than air can get out leading to the tank pressure building.
Old 06-14-2007, 07:14 PM   #12
actually, i still can't believe that so much pressure did build up. no, the filler spout is not threaded, but the hose fit snug. like i said, in the past the hose would just flop out once the tank was full, but this time it just stuck there and the tank filled like a baloon. still don't know how much damage was done, but please use this as a cautionary tale- DO NOT WALK AWAY FROM THE HOSE WHEN FILLING YOUR TANK!!!
Old 06-14-2007, 07:18 PM   #13
Aluminut
2004 25' Safari
. , Illinois
It's ok to walk away when filling. It's important to not jam the hose into the tank fill as it can nearly seal the fill hole and not allow air to escape, particularly if you fill it too fast. Yes the filler Bob mentioned will help and also let some air out from the fill area in conjuction with the vent hole as it looks smaller than a garden hose.
Don't feel bad, we've all be there in some capacity and as frustrating as it may seem, no sense in trying to stop a bomb once it's already gone off. Live learn, die and forget!
Bottom line, fill very slowly (not drips, just slowly) and you won't have any further problems.
Old 06-14-2007, 11:13 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Over filled water tank?
Hi, I don't know know how you did this, but from my experience, I have to hold the water hose in place by hand and I do not turn it on full blast. When my tank is full, water shoots out of the vent tube inside of the same door where the filler is. So what I am saying, you either have a tremendous amount of water pressure, or your vent tube is, pinched, restricted, or blocked in a way not allowing it to do it's job. If by chance you are still under warranty, and your vent is a factory defect, I would contact Airstream; Otherwise try your insurance company. By all means, don't just fix the damaged parts. Find and fix the cause of it all. I'm placeing my bets on the vent tube not doing it's job; With the vent working you would have to have a tremendous amount of water pressure and volumn to cause this to happen.
Good Luck and keep us updated on your results.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 08:33 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 07:09 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 09:36 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 12:54 PM
