Old 06-19-2007, 10:41 AM   #43
Originally Posted by ROBERTSUNRUS
Hi, Andy. Words from a Ford factory rep. In the near future cars will have a 42 volt system. How they came up with that, I don't know, but I don't know where they came up with 330 volts on their hybrid either. Also read in, I believe Motor Trend, Mercedes Benz was also going to use a 42 volt system. And no, this was not dislexia. (24/42)
The higher the voltage, the less currect, therefore smaller wire.
Just think how large cross country wires would have to be if we transmitted 220 volts AC overhead.
5 to 6 feet in diameter still wouldn't cut it.
Ah yes, when Airstream goes to 42 volts DC, then the 6 volt battery believers will have to install 7 of them.
Good luck with that dream, and weight, and space.
Old 06-19-2007, 10:49 AM   #44
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Ditto!
Originally Posted by azflycaster
I think alot of us did not know this type of damage could happen just by filling the tank. Thank you for posting this on the forums. You have spared many others from the same fate. Hopefully your airstream will be back to it's original condition soon.
Sending a little get well soon Karma your way!
THANK you for posting. This was something I was totally ignorant about. You've saved MANY people from potential problems.
Paula
Old 06-19-2007, 10:50 AM   #45
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Threads gone wild
What was the the original title of this thread?
ArtStream is offline   Reply With Quote
Old 06-19-2007, 02:10 PM   #46
2005 22' International CCD
Woodland Park , Colorado
hey all,
removal of the tank was pretty easy and have ordered a new one from AS. actually probably could have salvaged the tank but decided to not take any chances and replace it. the tank cover and straps i think can be salvaged, just need to get them back to proper shape.
the tank rupture did not damage any of the cross members; however we did discover some frame damage from the PO which had been hidden by the tank cover (definitely old damage, with rust starting to form - not caused by the tank overfilling).
have moved the rest of this project to the frame and floor repair section. http://www.airforums.com/forums/f36/...tml#post404371
thanks all for your help and advice. jk
JK3500 is offline   Reply With Quote
Old 06-19-2007, 11:24 PM   #47
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, now that you have the tank out, have you looked at the filler and vent hoses for kinks or restrictions? If there is room, I would cut a piece of plywood to fill the entire area within the frame section where the damaged floor is. Maybe leave an inch or so clearance all around just to be safe. Glue and screw the plywood to the original floor.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-20-2007, 05:38 AM   #48
Bob,
The filler hose looks clear. the vent hose was kinked (too long). will cut it off when i install the new tank. jk
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
