Old 06-14-2007, 11:35 PM   #15
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Bummer
I'm sorry this happened to you, especially just before you need it.
As far as the how...the vent tube is much smaller than the inlet tube. Then it becomes a matter of physics.
Multiply the width of the tank by the length, then multiply that by the pressure that the water exerted in pounds - it adds up quick. This is the same principle that allows us to lift a heavy truck with a rescue airbag using 120 pounds of air.
Example: a 24" X 24" airbag will lift almost 70,000 pounds with 120 pounds of air pressure. (69,120 pounds)
We obviously don't know exactly how much pressure there was, and I guess it really doesn't matter. It is a reminder to all of us, it's just too bad it had to happen to you. I'm sorry.
Dave
Fyrzowt is offline   Reply With Quote
Old 06-15-2007, 05:34 AM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Fyrzowt
i
"Normal" water pressure is about 35psi, I've seen it as high as 60. 35psi, and a surface size of about 30" square, will generate over 4000 pounds of force, more than enough to buckle the floor and some steel frame members.
Old 06-15-2007, 06:43 AM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
WOW, I didn't realize it was that much...I was thinking around 15psi.
Old 06-15-2007, 06:54 AM   #18
Images: 59
Terry,
Where did you get those numbers?
Check the math.
Old 06-15-2007, 07:16 AM   #19
2005 22' International CCD
Woodland Park , Colorado
Appreciate all your input on filling fresh water tanks and hopefully this will help prevent others from having something like this happen. In our case, from reading some previous threads concerning difficult tank filling, though I have not yet removed the filler tube I believe there may be a kink in it as it has always been difficult to fill as the water typically ran right back out of the filler neck unless the hose was inserted well into the filler tube, requiring the water to be "forced" in. Obviously in this case the water was "forced"in too fast and when the hose was not removed once the tank was full the continued pressure bowed the tank, cracking the floor and blowing out the bottom drain valve.
honestly, what we are really looking for now is ideas for how to fix. I know the water tank will likely need to be replaced, along with the tank cover and brackets, as they also are severely bowed. That seems to be fairly straightforward and I am sure when I remove the tank I will find other pieces that need to be replaced.
My larger concern is the floor, which is cracked and will need to be replaced. Can only the section of floor that is cracked be replaced or will I need to replace the entire floor? In other words, is there a way to fix this without gutting the entire trailer and replacing the entire floor. I guess the plus side is we could take the opportunity to replace the vinyl flooring with cork or wood....
Hopefully the insurance will cover this, as we do not have the time or $ right now to fix the floor. If not, we will just replace the tank and associated pieces and look at repairing/replacing the floor sometime down the road.
Right now though, we are going to pack up and head to the mountains for the weekend and deal with all this next week. Being long time dry campers with tents and then a small pop-up, we know that indoor plumbing and toilets are not a prerequisite for an enjoyable camping trip. Looking forward to an enjoyable weekend as I am sure when we get back the water tank will still be broke. jk
JK3500 is offline   Reply With Quote
Old 06-15-2007, 07:41 AM   #20
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I use a varient of this device to fill my tank. It fits into the fill inlet but does not block the entire inlet so air or excess water can escape.
Camco E-Z Fill Water Tank Fillers - Camping World
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-15-2007, 08:24 AM   #21
Aria's Avatar
1967 20' Globetrotter
Sauquoit , New York
Thanks for all the information. Something so simple. We would never think so much damage could happen. Thanks again. Aria
Aria is offline   Reply With Quote
Old 06-15-2007, 08:59 AM   #22
Originally Posted by JK3500
thanks for the info andy. the tank does not look hard to remove. i was able to push the floor dow to where it is now almost level, with only a slight bulge. the wood underneath the linoleum is obviously cracked.
however, we were planning on taking a short trip this weekend. right now thinking about still taking the trip (to crested butte), just without water, and surveying the damage when we return. question is, did the trailer likely sustain any structural damage from the tank bowing out or should I be ok for a short trip?
also talked to my insurance company and they are sending an appraiser out to determine if it is a claimable loss. hopefully so, as i am sure replacing the floor will be pretty extensive (and expensive). we'll see... jk
Your OK to make the trip.
Use the water tank. The trip will confirm if the tank is ok or not.
Water tanks are usually easily removed. Be patient though when you do it.
Your insurance company should cover the loss as a comprehensive loss.
You still need to inspect the chassis, for damage. A cross member could be damaged as well as the center frame support.
Old 06-15-2007, 09:16 AM   #23
Thanks Andy! Looking forward to the trip. Will send an update next week once we start tearing into it. jk
Old 06-15-2007, 09:20 AM   #24
Have a great weekend.
Watch out for those snow storms.
Old 06-15-2007, 09:21 AM   #25
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Some of our hydrants run 140# to 150# pressure. It becomes important to have a working pressure reducer for both house and trailer.
Old 06-15-2007, 11:09 PM   #26
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Terry. I agree with this except for the fact that how are you going to maintain this pressure even with, let's say, a 5/8" water hose versus a 1/2" vent tube. This would be like trying to fill a tire [with air] with a 1/4" bolt hole in it. With the water hose stuck in the filler and a blocked or pinched vent tube, this makes more since. Also like your gas filler on your car or truck, if the vent is blocked, it is very hard to fill your tank. My bets are still on a vent problem.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-15-2007, 11:30 PM   #27
Fyrzowt's Avatar
2000 25' Safari
Images: 8
I have never had a vent problem in any of my trailers, but I have over pressurized the tank to the point that when I remove the fill hose, a water column comes back out the fill tube, as well as out the vent. I think it could damage the tank that way if left in long enough.
That isn't to say that there can't also be a vent problem which would only compound the problem.
Dave
Old 06-16-2007, 06:38 AM   #28
Well Preserved
1993 21' Sovereign
Originally Posted by markdoane
Terry,
Check the math.
Sorry, that should have read something like "support", or "lift". I also moved a decimal point the wrong way, either way, it's still a significant amount.
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
