Old 04-22-2003, 02:10 AM   #1
68 Suburban's Avatar
Outside water hookup question.
The few times I have used my trailer, I have used the water that was in the tank. My question is, when you directly hook up to an outside water source, do you still need to run the pump, or does it go through the system by using the water preasure? Thanks
Here is the link to Dingo's trailer:
1968 Avion T-22
68 Suburban is offline   Reply With Quote
Old 04-22-2003, 06:00 AM   #2
It is not necessary to use the pump if you are hooked up to water supply.
Dan
Dbraw is offline   Reply With Quote
Old 04-23-2003, 08:52 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Normally you don't need to use the pump when you have a city water connection.
The Aquajet pump however in the current models will augment the pressure should the city water pressure be weak. You will need water in the freshwater tank to do it, but if the city water pressure is good, no need to use the pump.
Regards,
Eric
Old 04-23-2003, 10:18 AM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
In my 68, there is a filling hole for the front water tank, and I don't see anyplace else to hook up water, so can I only run off the tank? I have the original manual, but almost everything in it says 'this applies to all trailers (except 17ft model)'. Not that I mind, just wondering...
Stephanie
Old 04-23-2003, 10:22 AM   #5
airstreamcaravel's Avatar
Water Sources
Steph,
Mine was the same way also ... I adapted a T type water inlet
to use when at a campground. Works just fine. Is an easy modification. The inlet is in my "One Stop Service center".
DMC
airstreamcaravel is offline   Reply With Quote
Old 10-05-2013, 01:33 PM   #6
1978 Argosy 30
1971 31' Sovereign
san marcos , Texas
I just bought a 1971 Sovereign 31 ft, there is a filling hole for the front water tank, and I don't see anyplace else to hook up to city water, so can I only run off the tank?
Thanks!
foleywalker is offline   Reply With Quote
Old 10-05-2013, 02:25 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Thanks!
I found this group of posts. See if this helps. http://www.airforums.com/forums/f443...ter-65649.html
Jack
Jack Canavera
STL Mo.
AIR #56
water system question Alex Water Heaters, Filters & Pumps 1 01-17-2004 02:20 AM
'78 20' Minuet repair question: grey/black water drain valves Van All Argosy Trailers 4 01-06-2004 09:40 AM
Water question Tin Hut Fresh Water Systems 5 01-04-2004 07:52 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 12:12 PM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 10:38 PM
