Old 07-20-2016, 06:26 PM   #1
2013 28' International
Bozeman , Montana
Outside shower
My 2013 28' International has very low water pressure on the outside shower when running off the pump. There seems to be plenty of flow, just too many holes in the cheapo shower head to force much pressure. I did a temporary farm fix with taking the head apart and blocking about half the holes with tape which seemed to help but still not great, especially when holding the shower higher.
The inside faucets and showers are all fine with the pump. Has anyone else run into this and have any suggestions. I'll be at a music festival next weekend and grey water tank size might be a bit limited so the outside shower would be handy, even just for a quick cool down.
Thanks!
HeadWest is offline   Reply With Quote
Old 07-20-2016, 07:26 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Simple solution, Get a higher volume/pressure pump. I use my outside shower most every trip for cooling off or a quick rinse off of mud and dirt. Not the strongest pressure compared to my inside shower but gets the job done.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 07-20-2016, 08:00 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Metairie , Louisiana
Simpler solution— replace the outside shower head with one that matches the inside shower head.
WBCCI #1105
TAC LA-4
Engineering: Finding complex solutions to simple problems you didn't even know you had.
Old 07-20-2016, 09:18 PM   #4
Tn Traveler's Avatar
2006 25' Safari
Chattanooga , Tennessee
That's what I would try first. If you have a plastic housing and shower head it could well be the problem. If it still doesn't work well, look for a kinks in the supply line or an obstruction. Hydraulic pressure should be the same as any other line. Mine works great.
Don and Lou----Don posting
'06 Safari 25 LS
'97 Chevy Suburban K2500 Diesel
TN, Greenest State in the Land of the Free
" America is not a place;it is a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 07-20-2016, 09:18 PM   #5
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
I caught this screen shot of an outdoor shower hack on a video I saw yesterday. Install a removable screen with Velcro and it's a great idea! Click image for larger version
Name:	ImageUploadedByAirstream Forums1469067502.805787.jpg
The Evans' Family
Florida Panhandle
WBCCI 7091, Unit 153 & AIR 88474
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 07-21-2016, 07:35 AM   #6
AWCHIEF's Avatar
Images: 33
Glad my trailer has a working outside shower. Not thrilled by having to hang something out the window.
MICHAEL
Old 07-21-2016, 07:58 AM   #7
KJRitchie's Avatar
2008 25' Classic
Nixa , Missouri
I have yet to use my outside shower. When I winterized last year I noticed the hose connections were cracking so I purchased a new hose. Now I can't find the shower head. I hate when I loose stuff. As I remember the pressure was OK, not forceful but enough to wash off with. I have the original Aquaflo pump
Kelvin
2010 Tundra 5.7L, Double Cab, 2wd, White
KJRitchie is online now   Reply With Quote
Old 07-21-2016, 08:44 AM   #8
My outside shower gets used most often for cleaning things rather than people.
WBCCI #1105
TAC LA-4
Outside Shower? 1956Safari Sinks, Showers & Toilets 10 09-13-2008 10:19 AM
Outside shower in freezing weather Wayne&Sam Sinks, Showers & Toilets 6 11-21-2007 06:53 PM
outside shower jlester Sinks, Showers & Toilets 1 08-08-2005 02:35 PM
outside shower nevisstudio General Interior Topics 5 07-19-2005 12:24 PM
outside shower tandemfish General Motorhome Topics 3 05-24-2005 10:56 PM
