Old 07-17-2007, 12:06 AM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Question original tank sensors
where can I find original/original style sensors for the fresh water tank so I can still use the original readouts on the control panel? PO threw out the original tank.
goransons is offline   Reply With Quote
Old 07-17-2007, 10:20 AM   #2
The tank sensors in my tanks are solely terminations of electrically conducting wires. There is one live sensor at the bottom of the tank, IIRC, and 4 grounds at the various levels; 1/4, 1/2, 3/4, and Full. The liquid just completes the circuit between the live and the various grounds, and the lights illuminate in the panel. If, for example, the tank is 1/2 full, the Empty, 1/4 and 1/2 lights all illuminate. If yours were the same, the sensors are very simple, and I ordered replacement sensors from my local Airstream dealer for a few dollars. You would probably need to order them for a later trailer, like mine, rather than yours, as any catalogue would probably list yours as "unobtainable". They are designed to be glued into a hole drilled in the tank, and they are in the corner side wall near the outlet. They are very difficult to keep clean and operational in a black tank.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-19-2007, 07:53 PM   #3
goransons's Avatar
1963 22' Safari
sensors
I tried connecting the wires together, and they did infact light up the display, however I need to investigate more because it only lit up 0/0 1/4 and 1/2 and there doesn't appear to be power for lights for the 3/4 and full so I need to look inside. I definately need to rebuild for find replacement spring loaded switches, as they take work to get them to make contact sometimes.
Old 07-19-2007, 11:12 PM   #4
A good place to start looking is Farnell's catalogue, which offers 9,900 types of switch here:
Farnell Export=
Happy hunting!
Nick.
Old 07-20-2007, 09:25 PM   #5
goransons's Avatar
1963 22' Safari
switches
thanks! I'll have to measure and start looking, has plenty to look at!
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
tradewind holding tank McGill Waste Systems, Tanks & Totes 3 06-22-2002 09:28 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
