In our 2007 Safari 25FB we only get warm water in the shower. The kitchen and bath are hot. Is the problem in the shower fixture? o,r in the flow valves which appear to be in the correct positions.
Maybe the shower valve needs to be adjusted for hot/cold mix. Do you still have the manual to make those adjustments? You can access the valve through the access panel in the hall closet.
I took mine apart a year ago. There was gunk inside the cartridge. The issue is that you have to buy a cartridge puller to get to it. I got one from Ace Hardware.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
