Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 01-15-2017, 07:48 AM   #1
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
? On new fresh H2o tank
I'm going to order my fresh water tank this week and wondered the best way to vent it?
It will be going in a 67 Caravel. Above the floor under front gaucho. Same place it was originally.
The plumbing is being started from scratch. All the copper was split wide open.
Any other tips on how this should be set up would be much appreciated.
I have the new pump already & will be using PEX.
Is VTS the best place to get the tank? It is basically a long rectangle.
Thanks!
Dingo Girl is offline   Reply With Quote
Old 01-15-2017, 08:40 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
On my (2001 and 2002) trailers, the fresh water tank vent is a part of the fill port. The vent hose runs alongside the fill hose.
Al
Old 01-15-2017, 08:45 AM   #3
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
tank vent
my 65 caravel has a u-shaped copper tube that comes off the top of the tank and runs thru the floor and body pan on to the ground. newer tanks have a tube that comes off the top of the tank with a screened outlet just to side of the filler spout. It's usually a 1/4" tube, pex or icemaker tubing should work.
joe in minnesnowda
joqin is offline   Reply With Quote
Old 01-15-2017, 08:40 PM   #4
1988 Argosy 32
Lomita , California
PEX is best. don't forget to put a drain valve on the bottom to drain tank for winter or bad water dump. Run all water lines inside heated spaces to avoid frozen lines.
put in a inline filter for smell and taste. and to save water if dry camping a hand pump at kitchen sink
Wolfe is offline   Reply With Quote
Old 01-16-2017, 11:43 AM   #5
kdickinson's Avatar
Taos , New Mexico
Mine just vents around the screw on cover at the filler tube. The cover has two channels for the air and when the tank is full the water can easily pass back out the filler tube. There is no other tube from the fresh water tank
kdickinson is offline   Reply With Quote
Old 01-16-2017, 12:56 PM   #6
Central , Mississippi
Here is what I've been doing for a combo drain/vent. Yup, it's a sketch on a paper towel.
Name:	ImageUploadedByAirstream Forums1484596597.262025.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 03-07-2017, 04:07 PM   #7
Dingo Girl's Avatar
1967 17' Caravel
Thanks for all the insight on the tank setup. As soon as we get a few days in a row of decent weather it will be installed.
I really enjoyed the paper towel sketch.
Old 03-07-2017, 06:52 PM   #8
1966 22' Safari
Fredericksburg , Texas
This may be overkill, but this is what we did on our 1966 Safari. The multiple valves allow for different configurations. The fresh water tank is vented via the cap as pictured in the bottom left photo.
Good luck!
Name:	fresh water system.jpg
Bubba L is offline   Reply With Quote
Fresh water tank filling when hooked to city H2O. OffTheCouch Plumbing - Systems & Fixtures 13 03-18-2019 06:34 AM
Fresh H2O Tank Location Hans627 LP Gas, Piping, Tanks & Regulators 1 07-09-2015 09:39 AM
H2O heater, H2O pump, and winterizing the ponz Winterizing, Storage, Carports & Covers 1 10-19-2005 03:25 PM
Fresh H2O Tank Size?? RiskIt Fresh Water Systems 6 05-16-2005 01:23 PM
H2o leak from below (hot H2O tank ?) bigwoody Water Heaters, Filters & Pumps 3 09-27-2003 06:57 PM
