Old 06-08-2010, 10:04 AM   #1
2001 34' Excella
Edinburg , Texas
On board water system problem
I have a 2001 34' Excell & am getting it ready for travel. The on board water system will not pump from the tank. The water pump is new and works fine. I used it to winterize this fall and it pumped from the RV antifreeze bottles & built pressure and sut off just as one would expect.
The water tank is full. Any ideas as to my next step?
jbailey01 is offline   Reply With Quote
Old 06-08-2010, 10:08 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Is there a valve for the winterization? Is is set for the tank? Check the filter from the tank if you have one. Do not let the pump run for too long dry. It will break up the impeller.
Michelle TAC MT-0
Sarah, Snowball
Old 06-08-2010, 11:34 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I had a non-descript brass anti-back flow check valve a couple of feet upstream of my pump that bound up after sitting for a long time. A few sharp shocks via smacking it with a long screwdriver handle cleared it. It was just a brass fitting clamped in to a cut in the supply line from the tank.
Old 06-09-2010, 09:56 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Michelle may have hit upon it - if the pump worked when you were pulling from the antifreeze bottle, you may have forgotten to turn the valve back to normal flow position. Good luck.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-09-2010, 10:12 AM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
As others have said, you may have the three way valve just ahead of the pump set to draw from an antifreeze bottle instead of from your fresh water tank.
Assuming you do have it set properly, here is another tip that may help - I used to have to do this with my last RV that would have difficulty priming the pump from the fresh water tank in Spring.
If it wouldn't prime, I would draw water from a one gallon container using the antifreeze input hose, and while pumping, quickly flip the valve over to draw from the fresh water tank. It always seemed to work for me.
Just a suggestion!
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 06-09-2010, 12:08 PM   #6
2001 34' Excella
Edinburg , Texas
Thanks for the ideas everyone!!
I don't have a valve for winterization! The winter of 2009-10 will be the last time this Airstream is EVER COLD again!!! We are in the process of completing a move to the Rio Grande Valley TX and the Aairstream should be in TX, before the end of Oct.
I think my back flow valve is at the city water inlet after the pressure regulator. I have a new Shure Flow unit that I plan to use to replace the existing water inlets' pressure regulator that only allows a weak stream of water from the campground water supply (that is at 70lbs pressure). Perhaps this will solve my problem?
Thank again for ideas.
Jim Bailey
Old 07-29-2010, 08:17 PM   #7
make Wally proud
51cruisette's Avatar
1951 15' Cruisette
1948 19' Trailwind
Breckenridge , Texas
My pump is pumping but there isn't any water coming out of the faucets? What could be the reason? I have water in the tank too.
51cruisette is offline   Reply With Quote
Old 07-29-2010, 08:54 PM   #8
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
Believe it or not the most common problem like this, is sand and junk that is plugging the screens at the faucets. Unscrew all of the screens and see if there is a bunch of junk on them. This happens because most campgrounds and perhaps your home has well water. You should also pull the drain plug in the water heater and flush it out becuase the same junk will be in the bottom of that too. Let us know if that is it.
on edit: I am assuming that the water heater is full of water first.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Problem with 110 system dwahl24 Base Camp 7 01-20-2010 11:05 AM
Dinosaur DSI Igniter Board for Atwood Water Heater Ben4762 Water Heaters, Filters & Pumps 0 11-13-2009 07:29 PM
Hydro-boost brake system problem Andree Brakes & Brake Controllers 6 02-13-2009 05:12 PM
Need a little help with my water system please!!! jayk47 Plumbing - Systems & Fixtures 2 02-24-2007 09:46 AM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
