Old 10-27-2013, 05:12 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Unhappy Oil lines in my AS?
I bought a used air compressor to blow the water lines in my AS. I noticed, at the end of the process, a slight odor of oil in the compressed air coming out of a faucet. I THEN realized my oil- compressor was the source. It did not cross my mind that oil would wind up in the compressed air! Has anyone done the same thing - what were the results? I was on street water so the tank and pump were not affected. I'm hoping this episode will not result in major recovery operations.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 10-27-2013, 05:49 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Traditional compressors have oil in their crankcase just like engines - for the same reasons. That's why you can't use a regular compressor to fill diving air tanks - or breathing tanks for fire fighters, etc.
A lot of new (cheap) compressors are 'oil-less'. These use tuflon cylinder liners and would work better for your airlines. Go to Lowe's or Home Depot and look for compressors without oil fill and drain holes.
Silver Hawk is offline   Reply With Quote
Old 10-27-2013, 06:11 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
If your water lines have been contaminated with oil, I would guess a tedious process of flushing the pipes is in your future.
As RV antifreeze is alcohol based, I guess I would start with it. It might mix with the oil residue and allow one to flush it clean with copious amount of water.
If not, one might gave to use a detergent of some sort.
An oil less compressor or good quality separator is a must.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-27-2013, 06:45 PM   #4
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
JD
RV antifreeze flush is a good idea, I'll try it this weekend. I'll taste the water 1st to get an idea of how much oil may have stayed in the lines. I hope the anti freeze works - detergent may be hard to wash out too.
Air Cid
Reese WD Hitch
Old 10-27-2013, 08:34 PM   #5
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
I would use cheap vodka. (See my thread on the topic)
I hate the taste of RV antifreeze, and who can hate the taste of cheap vodka?
Make sure the hot water heater is by-passed and install an anti-freeze intake at the water pump, and it takes less than two gallons to clean the lines with clean tasting vodka. Oh yeah!
P.S. Don't be putting soap in your fresh-water lines.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-28-2013, 05:24 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Considering that oil is a carcinogen, maybe tasting the water to check for the presence of oil isn't such a good idea.
The problem with oil in your fresh water is Volatile Organic Compounds (VOC) in the oil. The best way to remove it is steam-cleaning, but that might be difficult in an Airstream's water supply system. Instead, flush your freshwater system with HOT water, from inlet to faucet, then go through another winterizing procedure to get rid of the hot water.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-28-2013, 07:47 AM   #7
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Another good point - thanks! I could use hot vodka if I Alumaholic is right
Air Cid
Reese WD Hitch
Oil change in a Classic Airstream 454cid crazeevw Mechanics Corner - Engines, Transmission & More... 22 03-23-2012 07:01 PM
Hydraulic brake lines Bandits Brakes & Brake Controllers 2 01-17-2012 06:17 PM
Towing and oil analysis pappy19 Tow Vehicles 12 03-23-2011 08:57 PM
Propane Gas lines exposed - 1968? Randy Gates 1965 - 1969 Globetrotter 5 03-06-2011 11:25 AM
Baby Oil - the magic bullet Foiled Again Off Topic Forum 19 01-04-2011 11:37 AM
