Old 03-11-2007, 08:22 PM   #1
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
Unhappy Oh no it wont move!!
Does anyone have pic on how to move the wood panel under the fresh water tanks.We tryed pushing up on it with two people it wont move at all.I would like to check them out to make sure everything all right since we replaced all the cooper pipes inside.We have the book but its not working like the book said it should....
The Clark Family
Angel73 is offline   Reply With Quote
Old 03-13-2007, 06:03 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Is it the wood panel that holds the water tank in place?
Old 03-15-2007, 06:15 PM   #3
Angel73's Avatar
1975 31' Sovereign
Images: 65
yeap
yes,with metel bars around all four sides.But it wont move with two people and a crow bar.
The Clark Family
Old 03-15-2007, 08:45 PM   #4
Well Preserved
1993 21' Sovereign
You will need to unbolt the angle iron retainer that keeps things in place. After you do that, you can lift up on the plywood and slide it out from under the tank. Make sure someone is holding the tank so it doesn't fall on you after the wood is removed.
Old 03-15-2007, 08:50 PM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
There's no wood panel under the water tank that I know of, or in the book?
Do you have a pic of what you're trying to do?
'77 Sovereign Intl 31' CB
Old 03-15-2007, 08:58 PM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The water tank has an angle frame that is welded solid on three sides, but has one removable angle, as Overlander 63 has stated.
The removable angle will allow the wood panel that supports the polyethylene tank to slide out and allow the tank to drop to the floor.
You will have to undo the fill pipe, vent pipe and level sensors.
Uwe
www.area63productions.com
Old 03-16-2007, 06:59 PM   #7
Angel73's Avatar
1975 31' Sovereign
Images: 65
hummm
We've done all that but the plywood won't lift up at all we tryed everything.We cant get it to move in anyway.Not sure why
We know it hasn't had water in it in over a years so the tank are dry.It just doesn't want to give us apeck at those tanks.L.O.L
And yes our does have plywood in a metel frame.And from what we can tell nothing until now has been changed in her.
The Clark Family
Old 03-16-2007, 08:23 PM   #8
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Floor Jack
We used a floor jack to raise and lower our tank.
Made up a wooden frame to spread out the force so we would not punch a hole or break the old plastic tank.
Easy does it.
R
fastrob is offline   Reply With Quote
Old 03-17-2007, 09:46 AM   #9
1972 25' Tradewind
Madison , Wisconsin
Good idea!
I am glad you posted that as I am planning on dropping my tank this spring. I am then going to take it out and have a dairy clean in place done on it. (Putting in new plumbing).
I think I will make sure I have a good brace built under everything before I even start.
Smokin Camel is offline   Reply With Quote
Old 03-17-2007, 09:56 AM   #10
Well Preserved
1993 21' Sovereign
The plywood slides, and the tank drops out through the hole.
My intro: looking to move to FL & live in Airstream keywestgail Member Introductions 8 08-27-2013 04:21 PM
preparing old Globe Trotter to move it mallet Axles 2 01-24-2004 12:34 PM
Just Curious Why? 53flyingcloud Our Community 21 12-12-2002 08:47 AM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
