Old 10-13-2014, 02:33 PM   #1
Wayward's Avatar
Cary , North Carolina
Odd plumbing find today
Getting ready to head out, I was putting away the WD-40 in the compartment next to the water heater bypass. This caught my eye.
The drain valve handle, stem and o-rings had snapped off. There is nothing heavy enough in that compartment to break it. I figured the last time I shut it off it must have twisted .
Justly lucky I saw it before we left so I could fix it. What a mess I'd have had when I hooked up the water at the campground.
New brass valve.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-13-2014, 02:53 PM   #2
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Glad you spotted the damages valve when did.
Like your replacement valve.
Please describe the PEX tool you used and how you removed the old valve.
That is a very cramped space to make repairs. It looks just like my 2007.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-13-2014, 03:42 PM   #3
Wayward's Avatar
There was a small clamp screwing the section with the valve to the floor.
I used a cutting disc on the Drexel to split the crimp rings at each end of that section - being careful not to nick the fittings. I pulled the valve and two pieces of old PEX out. I crimped two new pieces of PEX onto the new valve on the workbench.
Then I slipped the new section back onto the two elbows in the compartment and crimped them.
I have a combo crimp tool (1/2" & 3/4") from Home Depot. I was able to fully open the jaws inside the compartment . I put one handle of tool on the floor and pushed down on the other handle with both hands.
It worked!
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-13-2014, 03:45 PM   #4
Wayward's Avatar
BTW . The valve stem was corroded. Probably from water heater crud .
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-13-2014, 05:42 PM   #5
Alumaholic's Avatar
Images: 36
Thanks for your very concise and understandable description!
I'll be forewarned, armed, and ready to replace mine.
Ken L
Old 10-13-2014, 05:56 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The replacement valve is much better! Good catch.
Bob Martel
WBCCI# 5766
Old 10-13-2014, 06:37 PM   #7
Wayward's Avatar
You are welcome. You have me thinking that plumbing spaces are indeed tight on the Airstream.
This is the Shark crimp tool from Home Depot that I use for remodeling. It does 3/4" too but there is none of that on the Airstream.
So.......I think I need a few emergency plumbing tools on the Airstream including 1/2" and 3/8" PEX stuff and a cheap Dremel tool.
I think I'll go by HD and get one of these compact crimpers that works with vice grips.
A PEX pipe cutter:
A de-burr tool
few sections of pipe and an assortment of crimp rings.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-13-2014, 06:43 PM   #8
Chelsea , Michigan
Images: 12
A PEX pipe cutter:
A de-burr tool
Yippee, more tools! I love buying tools.
Bob Martel
WBCCI# 5766
Old 10-15-2014, 02:50 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Battery powered Dremel..
8200 12V Max Lithium-ion Cordless / Model: 8200
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-15-2014, 07:33 PM   #10
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for posting your find before a flood happened. I'll now inspect my old shut off valves for the same problem.
Otherwise it would be: Honey, why is the hall rug all wet?
David
Old 10-15-2014, 10:55 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
David
....yeas, when you are at the start of a 5 day trip...
Channing
WBCCI# 30676
Old 10-16-2014, 07:17 AM   #12
Chelsea , Michigan
Images: 12
Or boon docking miles from the nearest Lowes!
Bob Martel
WBCCI# 5766
Old 10-16-2014, 08:32 AM   #13
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
...the ratchet style clamps and crimp tool are MUCH easier to use ...
2015 25' Eddie Bauer International Sp Ed
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 11-08-2014, 03:26 PM   #14
Superannuated Member
Aironius's Avatar
2001 19' Bambi
Beaver Lake , Arkansas
The deburring tool requires quite a bit of space to rotate it, but it can easily be sawed in half. You lose the 5/8" size but are left with a close quarters 1/2" deburring tool.
Aironius is offline   Reply With Quote
Air Forums loading odd today? Or is it me? Keyair Forum Admin, News and Member Account Info 3 02-15-2013 12:03 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 12:01 PM
RV Story in USA Today--Today SteSpot On The Road... 0 05-18-2009 03:14 PM
Odd suburban furnace problem...any help out there? Couldn't find a similar thread! 101scout Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-19-2008 10:51 PM
Today's today, You know what that means? codybear Off Topic Forum 20 11-09-2006 12:31 AM
