Old 01-24-2006, 04:33 PM   #1
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
not enough hot water from kitchen sink faucet
Our '64 Safari kitchen sink has a hot and cold faucet..We can get good pressure from the cold water side, but for some reason, the hot water side just comes out so softly and in a small stream..any suggestions? It uses a 3/8" copper tubing
codybear is offline   Reply With Quote
Old 01-24-2006, 05:52 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Sounds like either a restriction in the line, such as a kink in the copper tubing, or the faucet is partly blocked. Both should be easy to find and fix.
Do all the hot water faucets have this problem, or just the one in the galley?
If it is only the one in the galley, check the line from where it seperates from the other hot water feed lines. Follow it to the galley, making sure there are no sharp bends, pinches, or kinks. If this is all good, and you have good pressure up to the faucet, you have a blockage in the faucet. A new faucet is relatively inexpensince, and not hard to change out.
Old 01-24-2006, 06:28 PM   #3
ga501's Avatar
1956 26' Crusier Overlander
douglasville , Georgia
I agree with terry, but before you replace the faucet, remove the hot water valve stem. I've seen the washer disenegrated and be in pieces plugging the hole in the seat. A simple cleaning and washer replacement does the trick.
If you don't know the brand of faucet, take the stem to home depot or lowes ; they have replacement stems and washers.
Steve
ga501 is offline   Reply With Quote
Old 01-24-2006, 10:20 PM   #4
codybear's Avatar
1964 22' Safari
Images: 315
We have replaced the faucet when we first had the problem to no avail..we'll try to check out the washer situation, thnx..
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 4 08-02-2002 02:07 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
