Old 03-25-2016, 05:35 PM   #1
1975 Argosy 26
chambersburg , Pennsylvania
Noisy water pump I've decided even though it isn't broken I'm gonna fix it
Ordered a shurflo revolution pump they say it's quieter , so that should make the wife happier I'll keep the original as a back up
Jimin pa
jimin pa is offline   Reply With Quote
Old 03-25-2016, 07:39 PM   #2
Rivets?
nvestysly's Avatar
1992 29' Excella
Van By The River , Georgia
We replaced our old ShurFlo with a new model and the new one is definitely more quiet. I don't think our new one is Revolution but I've heard (or not heard) it's one of the best?
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 03-25-2016, 07:56 PM   #3
Tincampers's Avatar
Sneedville , Tennessee
I use my old one to pump water into the fresh water tank.
Tincampers is offline   Reply With Quote
Old 03-25-2016, 09:15 PM   #4
1998 30' Excella 1000
Livingston , Texas
Jimin pa
If you don't already have it, a loop of braided flex hose on both sides, is good to have.
Siegmann is offline   Reply With Quote
Old 03-25-2016, 11:14 PM   #5
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Saskatchewan
In these cases of a loud pump sound is it normally the pump or the hose vibrating against something? Mine is also loud, but I've often though I could make it a lot better by moving a couple of the hoses. The issue seems to be that the hose moves back into its old place once you let go of it and the sound starts all over again.
Thanks in advance for any input
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 03-26-2016, 05:54 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Put some foam pipe insulation on those pipes and hoses where they contact something.
2012 Dodge Durango Hemi/AWD
Old 03-26-2016, 09:10 AM   #7
Arcticfox's Avatar
Great idea. I will try that - Thanks
Old 03-26-2016, 09:36 AM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Recently my pump has gotten noticably louder. Suppose I will get around to changing it one of these days but right now it is working fine so no reason to junk it just yet.
MICHAEL
Old 03-26-2016, 09:52 AM   #9
Wayne&Sam's Avatar
Images: 21
I also found that the board the pump was mounted to was loose and vibrating when the pump ran. I screwed the board in a couple of extra places and that made a huge difference.
Old 03-26-2016, 10:04 AM   #10
1975 Argosy 26
I like the idea of using the old one to pump into fresh water tank , I'm not replacing a shurflo with a newer model I'm replacing the original 1975 pump ( loud enough I don't flush at night)
Jimin pa
Old 03-26-2016, 11:11 AM   #11
2017 23' Flying Cloud
Falls Church , Virginia
waterpump
If i had only one complaint about these trailers, it would be the noise the water pump makes..., especially at night. I mounted my pump on a 1/4 inch piece of plywood, and glued a 1" thick piece of neoprene below that, and then glued it to the floor, and the pump did get quieter, but the shock distributed to the plumbing is still causing noise. I like the suggestion of braided segments on both sides, and pipe insulation around the individual lines.. That might work. There has GOT to be a solution.
bigreddog is offline   Reply With Quote
Old 03-26-2016, 11:40 AM   #12
1969 27' Overlander
Scottsdale , Arizona
I unbolted the from the floor cut and shaped a rubber foam pad about 1/2 " for the base between the floor and motor and then re-bolted it back to the floor using a shot of silicon in the screw holes with rubber grommets to deaden any vibration noise . Then made & placed a Styrofoam shroud over it to reduce the motor noise. It is virtually silent now just under the birthing of my 64 Globetrotter. Try it! Cost $13. in materials or if you have similar lying around use it.
BFSSBN is offline   Reply With Quote
Old 03-26-2016, 12:02 PM   #13
Tincampers's Avatar
Yours should already have flexible hoses on both sides. Most likely one or more hoses are in contact with something else causing the noise. Try to isolate the hoses and add the insulation.
Old 03-26-2016, 12:19 PM   #14
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
I purchased the shur-flo silencer kit and it made a big difference. I would agree that it is vibration making the sound. The kit adds curved hoses that absorb quite a bit of the vibration. You can still hear the pump but it does not sound like the side of the trailer is rattling. Previously the pump was directly connected in-line to the plumbing lines and made them vibrate. (the pic is not of my AS but from Internet).
WBCCI 8653
2015 Ford F-150 3.5 Ecobeast 3.55 Lariat
Off to another Trip #2..Just local, though THEPILL 2006 - 2010 International 2 03-07-2010 02:43 PM
The club that isn't even a club Frank's Trailer Works Other Clubs 80 02-24-2010 07:04 PM
Another Dilemma...A fun one though.. THEPILL 2006 - 2010 International 9 02-21-2010 07:58 PM
Battery at 45% even though connected to shore power SilverGate Batteries, Univolts, Converters & Inverters 27 04-17-2009 04:35 PM
