Old 04-06-2016, 10:17 AM   #43
Long Island , New York
Bob I think I will go with the ShurFlo OEM kit which has the plastic hoses,
http://www.amazon.com/SHURFLO-94-591...ess+connectors
on the off-chance that the hoses vibrate against something else, in which case the stainless hoses would be noisier IMO, albeit safer leak-wise. Given that (unlike hoses at a household washing machine which are usually under pressure), the ones at our FC20 pumps will only be under pressure every so often. YMMV
Peter
Old 04-10-2016, 12:07 AM   #44
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Peter
Peter I should probably share my conversation with JC. Originally I looked at the SFlo website and contacted them (twice). What I was seeing in the field appeared to look like what was on their website. I never got a response so contacted JC for a part number. Their response was non specific in that it was a plain ol' flex hose and not the kit hoses.
So maybe there is some dampening characterization to the kit. I'm not concerned about the pressure as the AS regulator is 65 lbs. SS may not be a real advantage here(IMO). At any rate, I'll await your experience.
For me...SS or SFlo kit will follow if I can't turn up the stereo any more ; )
CruizinDux is offline   Reply With Quote
Old 04-10-2016, 05:51 AM   #45
[QUOTE=CruizinDux;1774441
. . . if I can't turn up the stereo any more ; )
Bob[/QUOTE]
Thought maybe it was broke as you haven't posted any new songs. RIP Merle Haggard . . .
Old 04-10-2016, 06:34 PM   #46
comprose's Avatar
1999 31' Land Yacht
Kingston , Washington
As a former (perhaps still) boater, with over 16-years living aboard, I've had my share of water pump issues. Now on a motorhome, what I've done is install good thick (1/2-inch) rubber washers for the fastereners to the plywood. Second, and perhaps the most important, installed a pressurized accumulator. This stops the constant on/off running of the pump, allowing a more even water flow. Also cuts way down on wear and tear on the pump. You should be able to get this at most boating stores. My go-to resource is Fisheries Supply, in Seatle. They mail order.
comprose is offline   Reply With Quote
Old 04-10-2016, 06:59 PM   #47
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Get rid of the cheap noisy pump and you will find its a big improvement in itself.You will enjoy higher water pressure also.All for $110 and 10 mins.
Old 04-10-2016, 07:59 PM   #48
interstateflyer's Avatar
2017 25' International
Los Osos , California
Great info. Thanks.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 04-13-2016, 11:17 AM   #49
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I would like to replace mine but the water pump is located in an almost inaccessible location on my Classic 25fb. When you open the adjacent wardrobe floor hatch the water pump in not straight down but off closer to under the fridge. When I remove the panel behind the cabinet under the fridge its in the back. There are heating ducts, wiring and PEX pipes all around it. There isn't any available room for a new one and the Shurflo isn't plug n' play with the Aquajet with the clip-in hose connections. It would be difficult to get a PEX tool in there to modify the plumbing from what I can see.
Kelvin
KJRitchie is online now   Reply With Quote
Old 04-13-2016, 04:00 PM   #50
Tincampers's Avatar
Sneedville , Tennessee
Kelvin
You have to remove the clip in connectors. Does yours have the white hoses?
Tincampers is offline   Reply With Quote
Old 05-26-2016, 07:12 PM   #51
1975 Argosy 26
chambersburg , Pennsylvania
Name:	ImageUploadedByAirstream Forums1464307806.831667.jpg
ID:	263278 finished with my new surflo revolution next to silent wasn't even sure it was working till I put my hand on it . Appears to have better pressure too
Jimin pa
jimin pa is offline   Reply With Quote
Old 08-29-2016, 11:04 PM   #52
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
I am hoping to install a diverter valve to send city water to my fresh water tanks. Anyone do this and what hardware is necessary?
50 AMP Dual AC
AM Solar 570 watts
2 Golf Cart 6V Batteries
2012 GMC Denali HD Duramax
Pro Pride hitch
rp709 is offline   Reply With Quote
Old 08-30-2016, 06:36 AM   #53
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
These worked very well to re-mount our pump....
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Off to another Trip #2..Just local, though THEPILL 2006 - 2010 International 2 03-07-2010 03:43 PM
The club that isn't even a club Frank's Trailer Works Other Clubs 80 02-24-2010 08:04 PM
Another Dilemma...A fun one though.. THEPILL 2006 - 2010 International 9 02-21-2010 08:58 PM
Battery at 45% even though connected to shore power SilverGate Batteries, Univolts, Converters & Inverters 27 04-17-2009 05:35 PM
